removing the gauge cluster
Old Nov 28, 2007 | 02:06 PM
oohitztommy's Avatar
i just recieved a gauge cluster that i need to replace. i tried searching but i could not find any info on this forum. Would anybody have a write up for removing the cluster?
Old Nov 28, 2007 | 02:22 PM
moda_way's Avatar
Remove the plastic lower covers (2, over your knees under the steering column), undo two screws and with the steerin wheel all the way forward and down, tilt the cluster forward. I'm pretty sure I looked this up for someone before, but it looks very simple.
Old Nov 29, 2007 | 10:57 PM
RA032025's Avatar
in the 24th and a half...
You need to pull the driver's lower cover and the steering column upper cover...otherwise correct. Two connectors, a 18P and a 22P hold it after you pull the two screws, tilt forward (cloth recommended to protect) and unplug.
Rewriting the Odometer is the bear, the "Honda Diagnosis System" has to be connected before removing the old and the process followed to write to the new one. If you have replaced the cluster without this process, there is not a listed way to retrieve your mileage...and if the new cluster is not new it'll show the old mileage. If it is new, the odometer and all related functions will not work.
Old Apr 16, 2008 | 07:50 PM
suzook's Avatar
just to revive an old thread. my cluster stopped working the last few days. could i just swap in a used cluster? the local salvage yard has one with about a thousand more miles than my vehicle has now. could i just swap in the salvaged one? i dont care if it reads a thousand more.
Old Apr 16, 2008 | 09:56 PM
RA032025's Avatar
If the used cluster is the same year, it's gonna work....however...
You have to care about the mileage. You probably need witnessed statements (your vehicle mileage, the used cluster mileage, etc.) and to fill out paperwork with your local DMV.
Jul 16, 2017 07:33 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
CL-S progression 01
Jan 26, 2016 04:15 PM
Retep Nitciaj
1G RL (1996-2004)
Oct 6, 2015 01:36 PM
