Radio REplacement kit
I got a friend that just buy a TSX an wanted to replace the factory radio. I was wondering if anyone know where i can go buy dash kit for it? We found one but they was asking $800 for a factory kit.
Does any1 know where i can buy aftermarket DASH KIT?
Originally Posted by 97AcuraCL
doesn't exist, but u say you found one for $800???
I wnana see that!
post up
I wnana see that!
post up
I think it would help if you define what you mean by aftermarket DASH KIT?
I wish someone would make a way to install an aftermarket single din unit in the cubby pocket, and allow you to switch over to it like it's an aux changer, then you could run whatever you want from that Headunit thru the OE head.
Then you could keep the volume wheel switch etc. from the OE head and just set a mean vol. on the aftermarket heat.
then when you sell the TSX you could simply remove the aftermarket head. I figure this would work on the 7th gen Accord as well.
but you'd still be hooking up the speakers through the oe headunit. which would kinda defeat the purpose of an aftermarket head unit.
uh that already exists... doesn't it? a lotta people on the board use the kit adapter from the Accessory MP3 player to fit the single din fold out screens, you could put a regular headunit through it couldn't you?
But with that same adapter, you could also run an aftermarket head unit through it, and the adapter would allow you to switch from the stock radio to the aftermarket unit with the steering controls, etc.
So it could be done, but it does sound like you should really have a good reason ....
cycdaniel
12-17-2019 10:58 AM
Joseph Stansbury
34
12-04-2015 01:57 PM
handsom-hustla
11-13-2015 05:04 PM
