Please help with the security code!!!
Old Sep 1, 2008 | 03:02 AM
denny's Avatar
4th Gear
Hello there,
I imported a flooded acura tsx 2.4 2006 form USA. I had to replace the ECU and other parts in a local service. In my country ther is no Honda or Acura certified auto service so i just hired a good mechanic.
Unfortunately the navigation system asks for a security code that i don't have and the anti theft red led is blinking.
Does anyone know how and where to find that code or how otherwise to turn on that multimedia\navigation computer system?
Thanks a lot!
Old Sep 1, 2008 | 03:46 AM
MMsTSX's Avatar
JDM Addict
open the hood.
locate the fuse box.
shown in the picture below, circled:
take this cover off.
look inside the cover, for a sticker or a couple stickers.
there will be at least two numbers.
one is navigation, one is stereo code.
good luck.
Old Sep 1, 2008 | 08:54 AM
fast1's Avatar
Also look for similar stickers on the left outer side of the glovebox when it is open.
Old Sep 1, 2008 | 12:04 PM
dlee74's Avatar
So that is the code needed to enter into the radio after you install a new battery?
Old Sep 1, 2008 | 02:09 PM
MMsTSX's Avatar
JDM Addict
yes.
Old Sep 2, 2008 | 03:35 PM
cybereclipse's Avatar
私はより良い
and make sure its the four digit code u enter... not the other six-seven digit one
Old Sep 7, 2008 | 11:00 AM
denny's Avatar
4th Gear
Thank you guys for the information you posted, but unfortunately there where no stickers neither in the fuse box nor in the glovebox.
Is there some other way to find out this security code?
Old Sep 7, 2008 | 02:39 PM
JTso's Avatar
The suggested location from the previous post is not the factory assigned (default) location where the code can be found. It's up to each dealer where to place the code, although those might be the common choices. Mine is inside the owner's manual. You might try contacting a dealer in the U.S and provide the VIN and proof of ownership.
Jamus22
Jun 11, 2023 10:08 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
mars
Sep 28, 2015 11:03 AM
