PCV Valve questoins
Old Jan 12, 2012 | 01:49 PM
kewlliljethro's Avatar
PCV Valve questoins
Gonna do an oil change soon and I want to clean the PCV valve at the same time, and I need to clarify on some information
1. Where is it exactly located? I think it's above the alternator like in this pic
2. To access it, I'd have to take off the Vtec cover, remove hose and clamps, and use a 17mm to remove the actual valve?
3. To reinstall, there's a washer to replace as well (same as oil washer)? And what are the torque specs for reinstalling?
Thanks for any help!
Old Jan 12, 2012 | 05:39 PM
Simba91102's Avatar
Old Guy
That's it, but I didn't bother to try and clean it. I replaced them in the 05 and the 07 some time ago. It's about $20 for the valve.
Old Jan 12, 2012 | 05:50 PM
kbh's Avatar
kbh
What are the symptoms of this part going bad? Part number?
Old Jan 12, 2012 | 07:08 PM
TexasHonda's Avatar
PCV valves very rarely fail. If stuck open, you may get high idle when cold. If stuck closed, you will get oil vapor pulled into the PCV air intake on the air inlet duct. Lots of oily nasty on the duct and throttle plate.
Generally, if it rattles it's fine. Clean w/ a little throttle body cleaner and you're good to go.
good luck
Old Jan 13, 2012 | 09:04 AM
Simba91102's Avatar
Old Guy
good luck
Agreed. Some here have thought that their oil burning problems may be linked to a faulty PCV, but I'm skeptical. Others think a dirty/faulty valve can cause a decrease in fuel mileage. I'm skeptical about that one too. I replaced them basically because I could, and with over 100K miles on them, figured what the heck.
fifer16
1G RL (1996-2004)
Nov 22, 2024 07:07 PM
Mike734
Dec 10, 2021 01:25 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
prbori
Sep 27, 2015 01:37 AM
MilanoRedDashR
Sep 24, 2015 11:04 PM
