parking break light
parking break light
I noticed alot that the parking break light happens to come on alot now..you know the one with the exclamation point surrounded by the circle..
anyways..i have an AT and never use the parking brake..yet it comes on alot..
not sure what is causing this or why this is happening? can anybody please advise as to what may be the problem?
Originally Posted by allqt
yes..
Vehicle Stability Assist (VSA) adds side-slip control to the ABS and traction control. It works by controlling brake pressure, engine power or both to help maintain traction. Even if you take no action, VSA will reduce engine power and/or apply the brakes to reduce front or rear side-slip.
basically if its coming on more, you should probably drive a little more in control.
VSA light should only come on either when there is loss of traction or if the VSA is turned off. So unless you're driving like a maniac and forcing the VSA to engage, or turning the VSA off, you might wanna take the car to a dealer to have it looked at.
Originally Posted by LoveMyTSX
Speaking of parking break. I left my on yesterday and tried to drive and it alarmed. I didn't know the TSX alarmed when leaving the break on and trying to drive..........
It only kinda sucks when I'm doing my power sliding by pulling the ebrake
In the US, when the parking brake is applied it is shown with "BRAKE" in the instrument cluster.
Outside of US, (correct me if I am wrong) when the parking brake is applied, it looks like this: (!)
...The VSA Activation Indicator is the exclamation point within the triangle.
On page 60 of the Owner's Manual it states:
"If the indicator remains lit after you have fully released the parking brake while the engine is running, or if it comes on while driving, it can indiate a problem in the brake system."
yes it stays on until I turn off my ignition. We had some rain recently..and the road may have been slick..so that's what probably caused it..
rockyboy
Aug 4, 2024 10:35 AM
cycdaniel
Dec 17, 2019 10:58 AM
rockyboy
Jan 25, 2016 06:00 PM
