Park with e-brake or in gear?
My Garage
I've been seeing many of you with worlds of knowledge about transmissions, so I was wondering what puts more strain on the respective parts. Should I use the E-Brake when I park, leave it in 1st, or both? What is best for the car? Or does it not matter?
Thanks peeps.
Thanks peeps.
Both when on incline/decline and if I am on a level grade I just use the e-brake. On level grade, I fiugure the only way the car would move is if sombody pushed it or worse case scenario bumped it.
Wouldn't it hurt the tranny if it was bumped forward?
i put mine into either third or fourth AND use the ebrake
be careful if you stick it in 1st and use ebrake.
if you start your car forgetting that your car is in 1st you'll be in trouble.
Originally Posted by dzuy
do you guys always use first? what about any other gear?
Use all 3 Pedals at once
When parking uphill I use 1st gear and if parking downhill I use reverse and use the e-brake in both situations...
I do this just in case the e-brake fails, the gear will catch the car. And since it is in the opposite gear than which it is facing, it'll be harder for the car to roll and the car will lock up.
Moderator Alumnus
Originally Posted by Viking
I use first or reverse depending on which way the car is facing on the incline/decline.
![Agree](https://acurazine.com/forums/images/smilies/agree.gif)
Master Graphic Artist
I'm assuming you have an :mt: ?
Always park with e-brake and in gear (like Viking said, depending on which way your car is on the incline)
P.S. (Hey, where's the :mt: and :at: smilies???)
such a dirty birdy
Originally Posted by majormojo
There's a safety switch on the clutch - the car won't start unless the clutch is in.
i.e. for people who usually dont leave it in first. so if you suddenly start leaving it in first, DONT FORGET or the car will jump forward.
if you start the car while it's in first, then forget, then drop off the clutch b/c you're used to starting in neutral, then the car will hop forward. VERY dangerous.
that's why i leave mine in third or fourth, in case someone decides to start my car, but forgets its in gear, the gear is so tall that the car wont leap forward like it does in first.
On level ground I just leave it 1st or reverse. Any kind of incline I use both.
Depending on the kind of brakes one has, applying the e-brake hard after prolonged braking might speed brake warping (mostly true for rear drums).
In Europe it's not unusual to leave the car in neutral and without e-brake when the car is in a tight city street. People will then slightly move the car forward/backward to make another car fit or get out.
Originally Posted by biker
Kind of hard to start the car without the clutch in. ![Too Cool](https://acurazine.com/forums/images/smilies/toocool.gif)
here is an example of what i'm trying to say sheesh.
1. park your car.
2. leave it in first (person usually leaves it in neutral)
3. person starts car (w/ clutch down, duh)
4. person forgets it's in first b/c he usually leaves it in neutral
5. person lets go of clutch
does that make sense now? that's what people should be careful of, not forgetting it's in gear. i never said you could start the car w/o a clutch
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
you guys still arent getting it.
1. park your car.
what you guys are talkin about
1. park your car.
![n00b](https://acurazine.com/forums/images/smilies/n00b.gif)
UK Spec
no i meant if you start your car, then let off the clutch AND you forgot the car was in gear.
yep done that a few times
OUCH....
![Uzi](https://acurazine.com/forums/images/smilies/uzi.gif)
such a dirty birdy
1. park your car.
1. park your car.
CG is the place to be...
Why would you drop the cluth anyway?? When i start the car, I ususally do it for the purpose of driving... thus I put the car in gear and drive away.
Boy Genius
No AT drivers chiming in? I see a lot of AT drivers who never bother to use the parking brake at all, and those who do often engage it after they've put the car into park. This is not usually a problem on flat surfaces, but if the car is on a grade, shifting into park first puts the weight of the car on the transmission as opposed to the parking break.
On an automatic, I usually bring the car to a stop with the brake, leave it in D, apply the parking brake, let off the brake, then shift the car into P. To get out, I start the car, apply the brake, shift the car into R or D, release the parking brake, and then drive off. I always get so many comments from people telling me this is wrong - what do the other AT drivers do?
NBP/EBONY/6MT
I have firsthand experience of my TSX e-brake slipping and the car rolling out of a parking space. Thankfully the car didn't roll very far back because the parking lot leveled out, but that was a quick reminder that you should ALWAYS put it in gear.
Personally, I'd say 1st or reverse. Depending on the hill, the car could eventually get rolling in a higher gear. Yes, you could forget, but it becomes a habit after awhile. Its like forgetting where the volume is on your steering wheel.
such a dirty birdy
Old fart
With my TSX, I either:
pull the ebrake, then shift to park
shift to park with foot still on the brake, pull the ebrake, let go of brake
and sometimes, don't use ebrake
with my Solara:
ebrake, then shift to 2nd/3rd/4th, or if I'm parking downhill, R
OK, OK. I see what you mean. But what you're talking about is just a change from the person's normal routine and habit. I've been parking my MT cars in 1st for over 20 yrs, I NEVER forget it's in 1st because that's the way it's always been and always will be.
And I never have to wonder if I remembered to set the parking brake because I always do that as well (on AT vehicles too). ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
6MT Snob
Originally Posted by JTso
Okay, I'm going to throw in a twist.
If you just finished high speed driving with heavy braking, don't use the e-brake. Just put in in gear. Because you can potentially warp the rear discs.
ATCer
I agree, and since I am usually pretty hard on the brakes, I always leave my car in gear when parked. I've had rotors warp due to cooling with the e-brake being on, so since then, I've never used.
