Navigation is locked and code does not work
Old Nov 18, 2007 | 08:49 PM
psteng19's Avatar
I inputted the code found on some tags on the keychain on the valet key - no go.
Can Acura resolve this over the phone?
What's stupid is it locks out not only the Nav but also the AC and audio controls
Old Nov 18, 2007 | 09:47 PM
TacoBellSauce's Avatar
that istn the navi code, thats the code to get your keys replaced
look in the manual or in the papers that came with the car, it should say there somewhere
if you cant find it, call up acura and give em your vin
Old Nov 18, 2007 | 10:58 PM
snailspeed's Avatar
Do you have the codes in the glovebox, owners manual? Usually two plastic cards with codes on them.
Old Nov 18, 2007 | 11:06 PM
snailspeed's Avatar
If you open the glovebox, look on the outer left side and you should see the codes on two stickers. One is 5 numbers long, the other is 4 numbers long.
Good luck.
Old Nov 19, 2007 | 05:59 AM
nj2pa2nc's Avatar
it's a car-drive it
like atm cards you only have 3 changes to put in the right pin-numer. otherwise it locks ups- your nav. code probably is with your owners manual and other things the code you are using is to get replacement keys, if you wait a bit atfer you mess up on the code you can start again
Old Nov 20, 2007 | 07:25 PM
psteng19's Avatar
Called the dealer and they had the code in the system.
Worked like a charm, thanks!
mada51589
Jan 9, 2025 04:40 PM
Ol'Dave
Sep 5, 2020 02:56 PM
acurajj
Sep 19, 2015 03:47 PM
ahsm
Sep 9, 2015 08:35 AM
