maintenance service??
Hi guy, i have an 06 and already have 59,000 miles on it, so is it time for tranmission fluid change yet?? And when is time to tune up, replace spark plug, belt,...etc, and what about the timing chain? do i need to change it when hit 100,000 miles
A transmission fluid change would be good.
The timing chain doesn't need to be replaced till 120-140K.
As far as the other things, I'm not sure. Like I just mentioned in another thread, if you just follow the maintenance minder, and check the service booklet for whatever letter/number combo comes up (A1, B2...etc), it will tell you much of what needs/should be done.
it's a car-drive it
follow the maintenance minder. I do mostly highway driving so I was advised by my good friend, a acura service manager, that I should have my MT fluid changed every 3 years. My 06, bought new 11/17/06, has 65,000+problem free miles.
The Maintenance Minder is good if and only if you have been following it. If you have not, then 60k is a good time to replace the engine and cabin air filters, flush the brake fluid (if it has been more than three years), as well as service the transmission.
The timing chain does not need to be replaced as normal maintenance. The serpentine belt, spark plugs and valve adjustment are due when the "4" code appears, or around 110k.
08_UA7_Gr33k
02-11-2016 02:17 PM
