Maint. Req'd Light
Old Oct 25, 2005 | 12:41 PM
War Eagle TSX's Avatar
Maint. Req'd Light
I noticed this morning when I fired up the car that the Maint. Req'd light was flashing. (Not the normal when you start the car and its on, but really flashing) I know I'm due for my next oil change within 300 miles. My baby is still fairly new she has 8,100 miles on her since June.
Is this light flashing in reference to my oil change or will there be something else? Teach me ol' wise ones!
Old Oct 25, 2005 | 12:42 PM
TSX.Fury's Avatar
send me a link to JDM??
How many total miles? It's not gonna be the oil change, but it could be a service light. The light comes on at 10k 20k etc. etc.
Old Oct 25, 2005 | 12:43 PM
GIBSON6594's Avatar
My Garage
It's just telling you to bring it in for a scheduled maitainence. You can turn it off yourself, i'm pretty sure you just hold the reset button for about 10 seconds with the key in the "on" position.
Car has 8,100 miles on it.
Old Oct 25, 2005 | 12:49 PM
TypeRS's Avatar
Got Ramen?
yea it started doing that to me at arount 8000 miles (i'm currently at 9100). It's just a reminder tat it's nearly time for service.
Old Oct 25, 2005 | 02:42 PM
weapon-x's Avatar
Got to love this forumn someone always seems to have an answr to a problem/question I'm having- I just started getting the flashing maint. required light yesterday morning.
Course I'm at about 20K so I'm sure I need oil change.
Old Oct 25, 2005 | 02:58 PM
jlukja's Avatar
Big Trouble
Maint. Required Light can mean several things, all of them bad.
a) No oil in the engine, it may seize up any moment.
b) Fuel system leaking, engine using bad fuel mix, need new engine
c) Oil and coolant mixing, main gasket blown, need new engine
d) overrotation of valve cams, valve springs need changing
e) overfilled blinker fluid, electrical system problem may result.
or, if you you'd know its just a normal. The system is reminding you that 10K service is coming up.
Old Oct 25, 2005 | 04:58 PM
Wolfpack_TSX_22's Avatar
I'm pretty positive to reset it, you hold the milege reset button in while turning the ignition (not starting the car, but the one before the starter) on 4 times.
Old Oct 25, 2005 | 05:07 PM
rpcmx's Avatar
No, this isn't an Audi, nice try.
See above.
Heh.
Can you even overrotate a valve cam? Can you rotate a valve cam period?
Enjoying this forum when he should be doing work,
-rpc
Old Oct 25, 2005 | 06:17 PM
ordad's Avatar
Maintenance light
I have the same problem and have tried to turn off the Maintenance Required light using the two methods suggested, but to no avail. Anyone else have any suggestions?
Old Oct 25, 2005 | 06:22 PM
CJams's Avatar
Guinea Pig
unplug battery?
Old Oct 26, 2005 | 12:44 AM
grasseater's Avatar
i don't remember off the top of my head how i did it but i know it tells you in the owner's manual how to reset it.
Old Oct 26, 2005 | 08:40 AM
fast1's Avatar
maintenance light flashes at startup (I think 10 times) when you are at 8,000 miles from the last reset. At 10,000 it should remain illuminated to get in your face and have you come in for service
Old Oct 26, 2005 | 09:42 AM
ianS's Avatar
Old Oct 26, 2005 | 09:48 AM
Thnx Guys!
Old Oct 26, 2005 | 10:20 AM
jlukja's Avatar
http://www.acura-tsx.com/forums/show...ntenance+light (look at post no. 3)
^^ just some of the threads I found on the topic. Hope this answers the question.
Old Oct 26, 2005 | 02:55 PM
Very helpful! That puts my mind to rest!
mada51589
Jan 9, 2025 04:40 PM
Dec 7, 2020 05:39 PM
heykosal
1G RDX Problems & Fixes
Feb 27, 2016 06:43 PM
Greengecko
Sep 16, 2015 08:19 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
