LED Turn Signals
Old Oct 5, 2006 | 11:12 AM
xenonhid's Avatar
CGP Ebony
LED Turn Signals
I'm interesting in having LED's for my turn signal.
Here is the installation
Does anyone have any suggestions or Pictures of where I mount the Load resistor?
They get hot so it needs to be away from Plastic, or any other wires.
Old Oct 5, 2006 | 12:08 PM
Reach's Avatar
They do get hot, but not super burninating hot. Additionally, since they are turn signals, they are barely ever on, so you don't have to worry about them too much. If they were for LED tails, that would be a different story.
As is, for the front turn signals just use some foam double-sided tape and tape the bottom of the resistor to an open piece of frame. All you really need to do is make sure they won't slide around, and that will do the trick.
Old Oct 5, 2006 | 12:11 PM
xenonhid's Avatar
CGP Ebony
Arigato Gozaimasu!
Old Oct 5, 2006 | 12:28 PM
rex.'s Avatar
Is waiting in
Old Oct 5, 2006 | 12:35 PM
xenonhid's Avatar
CGP Ebony
Thanks for the pic, did you have to drill?
Old Oct 5, 2006 | 12:42 PM
rex.'s Avatar
Is waiting in
just the self-tapping screws.. very easy though
Old Oct 5, 2006 | 02:57 PM
xenonhid's Avatar
CGP Ebony
Old Oct 25, 2006 | 01:56 AM
xenonhid's Avatar
CGP Ebony
Can someone elaborate on why the instructions say to use 3 Ohm Resistors IF I was to do the Both front and rear?
Why can I not use 6 Ohm resistors for both front and back?
Old Oct 25, 2006 | 06:51 AM
moda_way's Avatar
I believe the resistance of stock bulbs is 3 Ohms. Not sure if the resistance of 6 Ohms would slow down the relay.
Old Oct 25, 2006 | 10:25 AM
Reach's Avatar
I'm using 6ohm resistors on each turn signal, no problems. It was just what I could get for free.
Old Oct 25, 2006 | 10:32 AM
moda_way's Avatar
Nice! I wasn't sure.
Old Nov 18, 2006 | 07:41 PM
xenonhid's Avatar
CGP Ebony
Thanks for the advice, I'm going to use a total for 4 6OHM load resistors.
Since it worked with REACH's turn signals.
Will post pics and movie after installation!
Old Sep 30, 2008 | 10:48 PM
xenonhid's Avatar
CGP Ebony
^^ Edit, all you need is two 3 Ohm resistors in the front and that covers the front and back.
There is no need to buy four 6 Ohm resistors.
Old Oct 1, 2008 | 10:43 PM
litesout's Avatar
Oliver!!!
Wow, talk about going over the 5 minute limit to edit a post
Old Oct 2, 2008 | 01:23 PM
kaliraver69's Avatar
So you don't need to install any in the back if you just put two in the front?
Old Oct 10, 2008 | 06:20 PM
xenonhid's Avatar
CGP Ebony
Cool
^^ Yes, Thats correct. I wanted to clarify so that others won't go off and purchase 4 load resistors which is not necessary for your car or your wallet.
To give you an update, I've been running the load resistors with LED Bulbs for all turn signals and they are doing just fine for more than a year.
As for mounting the load resistor, Using 3M double sided tape is the way to go so you don't have to drill.
I recommend this mod for anyone looking for the instant On / Off look for turn signals since your side mirror signals are LED's already.
pplcrew
Jan 30, 2021 08:59 AM
Sep 17, 2015 09:01 PM
Greengecko
Sep 16, 2015 08:19 PM
JnC
Sep 11, 2015 06:06 AM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
