Just installed my led dome lights...
Is it just me...or if u turn the switch to off, instead of being off, it turns green...to turn it off it has to be on the default - on with doors, off with ignition setting.
Somehow there's a small voltage applied to the lights even when it's suppose to be off. The voltage is too small to turn on the normal bulbs but the LEDs are more efficient and turn on with the smaller voltage thus you see the small glow. If you drive your car at least once a week you should be fine, no need to worry about battery drain.
Boost Junky
i only see the 9 LED ones...also did you get the HID white ones? I just did the license plate 1 Watt LED's from tec toyz and they look really good as well
I spend 2 much time here
damn 5 minute edit rule, yes i meant to say 9 led. i thought this might be too many at first but it actually is perfect. i got tired of the blue leds i had before as i couldn't really see shit with them.
yes hid white
yes hid white
yeah i have white maps with blue else where, i think im gonna up the lights cause its a bit too subtle...but none the less an excellent mod...too bad its so damn hard to take the plastics out w/o slight imperfections on the car...
Greengecko
09-16-2015 08:19 PM
