How to remove the rear seats? Where is the nearest 12V?
I can't find my garage
i did try searching, but i was unsuccessful. i need to know how to remove the rear seats. does anyone have any info on how to do so? any help will be appreciated. thanks
The rear seat bottom is pretty easy. There is one bolt that holds it to the frame. Its located just about where the seatbelt protrudes between the left and middle passenger. Just slip you hand between the back and bottom cushion and feel for it. Once you undo the bolt then the entire rear bench pops out when you pull up on it.
Professional Newbie
Don't be afraid to pull up on it once you've undone that bolt. There are two clips on the bottom of the front of the seat. They are right in the middle of seat horizontally on either side of the middle seat. Give it a good yank upward from the front.
You taking it out for a fun project? or did you just drop something expensive underneath the seat?
Originally Posted by CGTSX07
does anyuone know what size this bolt is or where i can get one? I took mine out for the tein ss installation and have no idea where it is anymore
i appreciate the help guys. i do have one more question though, its totally different so i didnt want to open up another thread. can anyone tell me where the nearest 12v hot wire is near the left side of the steering wheel to install a switch in the blanks.
Originally Posted by White92
I used the 12volt power outlet inside the "not an ashtray" compartment. Just buy the taps at radioshack. I got a back of them for a couple of bucks, but only needed one.
