View Poll Results: Did your TSX require an alignment after drop?
Yes
14
87.50%
No
12.50%
Voters: 16. You may not vote on this poll
How many of your TSX's required an alignment after lowering?
My bolonga has a 1st name
1 Post
I'm getting prokits installed with the rear camber on thrusday.... wondering if it will be NECESSARY to do an alignment?
If ya post... Please include...
What Brand Drop:
(Tien Coilovers, Eibach Prokit, Aspec, whatver)
How Low is the Drop:
If Springs did you also put in new shocks/struts?:
Did you put in a rear camber kit?:
Did it require an alignment afterwards?:
What Brand Drop:
Someone stole "My Garage"
With a camber kit, and especially with any drop, its worth the $$ to get it done. Eyeballing it won't work... and if you don't get it done, you might just have kissed a set of tires goodbye. An alignment is cheap insurance on the tires and handling, IMO.
Rep'n Taxbrain.com
Get it aligned. You might want to consider the Firestone Lifetime alignment package. The only drawback with it is that if your car is too low it might not fit on their rack.
1 Post
its just the prokit drop; so 1.4 rear 1.2 front...
but yea getting it on the rack was what i was most worried about; beacuse i've got a long trip this weekend. I guess i'll be getting an alignment...
has anyone with this drop had trouble finding a place to do it?
1 Post
what are average prices of such alignments? and should i have a problem with getting it on the average rack at a tire kingdom or tiresplus or midas etc...?
1.2 front, 1.4 rear
1.2 front, 1.4 rear
JDM whore in training
Get it aligned no matter how low you go..
.. I got an alignment for around $92.00 the first time I dropepd my car ... the other times I dropped it again, I got rejected due to the agressive drop... they told me to raise it up and consider putting camber kits on so my tire wear wont be so bad..till this day.. my camber kits are sitting at home collecting dust.. while I run on a rear -3.2 and -4.0 camber.. ... You shouldnt have a problem on getting up on the rack unless your drop is lower than my 3 1/2'' drop ..
Received 3,791 Likes
i needed one really bad after I got my car lowered. Felt like the car wasnt even drivable.
I think some of the newer Hunter alignment racks are built closer to the ground surface because of lowered cars these days. Good luck finding a shop though that has a newer one of these, as they only maybe present in aftermarket speciality shops
Guess I'm the first that didn't "need" an alignment. I'm putting quotes around the word need because of the fact that I still intended to get an alignment after installing my aspec just to find out everything was still within spec. This was after 2 weeks of letting the springs settle in.
The alignment will change after a drop. Do you need to take it in right after drop? I guess it depends on how the car drives and tracks. I didn't get the alignment done until a few weeks later after each suspension setup that I've tested. The car was tracking perfectly straight and I wanted to wait for it to settle a bit before taking it in.
Koni / Neuspeed Sports (F&R camber kit)
F =1.5 R =1.0
Koni / Eibach Sportline (F&R camber kit)
F = 1.9 R = 1.6
Tein Flex (R camber kit)
F = 1.9 R = 1.6
F =1.5 R =1.0
F = 1.9 R = 1.6
F = 1.9 R = 1.6
Bye TSX, hello domestic?
Originally Posted by xizor
No, for most generic tire place racks I couldn't get up w/ a ~2.3in drop, my front lip would hit part of the ramp. I finally got it up using wood planks, but I dropped it more and said goodbye to the generic places.
1 Post
i'm getting the prokits and the SPC camber kit installed by one place... and was going to take it to get he alignment the next day by a different place....
i was assuming that the camber would be adjusted by the place thats installing it.... if they dont know the specs to do so, should I have any information before hand to give to the camber kit installers? the camber kit isn't new, i purchased it from kaikai114 here on the forums.
A-Spec drop, no camber kit here.
Have camera, will travel
I'd say the A-SPEC is probably the only one that wouldn't require an alignment
cycdaniel
12-17-2019 10:58 AM
DiamondJoeQuimby
09-10-2015 11:40 AM
