How long do your brake pads normally last.
Starting a new thread on this.
I've been told brake need to be changed. I have about 32,000 miles. This seems premature to me.
I'd like to hear when some other TSX owners had to change theirs.
I'd tell them no. Go home, inspect them yourself. Or take pics and post em up here so we ca decide.
If they do need to be changed, do it yourself. Last thing you want is OEM front brake pads.
My AT front pads were changed at 75K and they still had 10-15% left. My MT wth 85K still as far as I can see has the original pads on, but they are well below 10% left.
Then agian maybe you brake too much.
IMHO pads typically last around 30-35K miles (roughly 50K km.) but a lot of it has to do with your driving style. At my last service (18800mi.) they told me I was only down 2mm on the pads.
In the other thread (https://acurazine.com/forums/showthread.php?t=31769) you said that the dealership is machining the rotors. That could be why they're recommending that you change the pads. Did you ask them if their recommendation was wear based?
shit, i'm divulging all my tricks for free...
![Doh](https://acurazine.com/forums/images/smilies/doh.gif)
new pads on old rotors = OK
old pads on new(or turned) rotors = not OK
I spend 2 much time here
50K miles on mine and I just recently had a mechanic look at them when i was getting comptech headers installed and they still plenty of material left...regardless i still think the stock brake pads suck.
Someone stole "My Garage"
I believe there's a brand new set of Hawk HPS pads for the TSX in the Black Market section right now.
FDL, if I were you, I'd get these and then have the Acura tech install them (labour is free, right?) when they machine the rotors.
The Hawk HPS pads are NIIIIICE (good initial bite, relatively low dust, and great fade resistance). Had 'em on two previous cars and will put them on the TSX in about 25,000km when these brakes are done.
My rear pads were swapped out at about 23k miles on my 04 and I did the fronts at about 25k. The rears were almost totally done when I changed them out, but the fronts had a fair amount of pad life left on them. Of course, I do mostly city driving, so that generally is harder on the brake pads.
Originally Posted by feelgood13
you shouldnt have to change your brakes unless it squeals. and when it gets to that point, a couple spritz of wd-40 now and then will take care of the annoying squeals.
Originally Posted by JTso
WD-40 is not the correct lubricant for brake components. In fact, WD-40 has many uses but was never advertised as a lubricant and shouldn't be used as such.
Sure, it seems to prevent things from rusting/seizing, but that isn't because of lubricating properties - it's because of it not allowing water to ozidize the metal.
JTso is right again.
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
at high speeds, i would say above 80mph, when i brake hard for a second, there is a slight vibration in the steering wheel, doesn't feel like the rotors are warped (cause i drove a car that had warped rotors), but upon normal braking at slower speeds, it doesn't happen.
i have close to 30K miles on a new 2005.
is this because of the weak rotors? bad pads?
Brake pads need to be changed before they are down to the metal and ruin the rotors, even without squeals. WD-40 is not the correct lubricant for brake components. In fact, WD-40 has many uses but was never advertised as a lubricant and shouldn't be used as such.
no0bIe
My front pads on my 04 Accord with 42k at trade in had 50% of pad left and i owned it exactly 2 years.
my tsx with 16k miles had damn brake pulsation so i got them to install new pads and rotors for free.
once i replace them i will use Brembo blanks and Hawk or PBR pads
Originally Posted by Aziancreeper
If WD40 is not the correct lubricant for the squealing sound, what is the correct one? I have 32,000 KMS and do not need to change my brake pads yet, but this squealing is something i want to fix. the dealership says they cannot hear anything, but i hear it all the time? any ideas?
I went 89,000 miles on the original pads of a GM prior to changing them out. And this was with mostly city driving of 1-3 mi trips. If I can gain access to a camera, I'll post some pictures of the pads. There's still some material left on them.
I replaced with AutoZone Ceramic pads in the front and Semi-Metallics in the rear as I was a cheapass.
Driver/Detailer
Originally Posted by drivelikeafighterjet
I had to slam on my brakes at about 105 mph and now they seem to vibrate slightly when I brake normally. Does that mean new rotors?
T.DoT P.I.M.P. lol
1 Post
Originally Posted by Still Water
Before I upgraded the whole braking system, my rears were wearing down twice as fast as my fronts. The TSX is my 3rd FWD car and I've gotten in the habit of modulating the pedal to bring in the rears while braking rather than nose diving the front end of the car. I found that the TSX, given the right setup, does a very good job of 4-wheel braking under control and will use the rears if called upon retaining a more neutral feel. This was one of the primary reasons I upgraded the pads, rotors & lines. My only wish is that the rear rotors were the same size & configuration as the fronts. And yes it would look better when parked next to a B-mer.
I'm switching my front pad to Hawk HPS soon, I hope it helps braking when it gets hot.
Originally Posted by chuson
How do you know if the car is braking w/ the rear or just front or all 4 together?? I mean how can you manage to control it??? Is there some technique require???
Drive with your butt - modulate the brake pedal - feel for more of a squat vs. a dive.
I was quoted $213 for just the rear pads. My tsx has 34Kmiles on it and i was just informed that i'll need new rear pads before my next oil change. Where is a good place to get good pads online?
My brakes squeal and the dealership insists it's normal and cannot hear anything.. This might sound stupid and obvious, but are you spraying the WD40 right on the rotors? The squeal when i brake very lightly, is annoying the heck out of me.....
There's a TSB (at least in Canada) for squealing breaks on early build 2004s. Apparently, they changed the design of the pads part way through production in '04.
thanks
Originally Posted by Alin10123
Hows the squeeking? Are they as quiet as OEM? Did you use the stock rotors? Also, was it a huge improvement over stock in terms of braking quality? Did you get them on the front and back? or just the front?
thanks
thanks
Used new Brembo blank rotors with them, and used the Hawk embedding method (a series of controlled hard stop to heat-treat the pads and get the right amount of pad material transferred to the rotor... its on their website).
Improvement over stock was VERY noticeable. Initial bite was much greater, and overall stopping power was considerably improved. I can just imagine the Hawk HP+ pads.
![what](https://acurazine.com/forums/images/smilies/what.gif)
Just had them on the front, and had "F1" pads that my parts supplier recommends, on the back.
As for feelgood13's comment - there's a reason he was banned (being a retard).
Bye TSX, hello domestic?
thanks
thanks
mada51589
05-03-2022 08:54 PM
