How to control HVAC without Navi Screen or Voice
Does anyone know if there is a way to increase fan speed and change fan modes without using voice control or navi. Sometimes I don't bother pressing the ok button on the navi and it shuts the screen. But to voice activate the fan speed you have to press the ok button or it won't work. Is there a button on the center console that increase fan speed and changes modes or can you only change it on the screen and voice? Some quick way to do it?
Originally Posted by daniel1113
Someone needs to figure out how to bypass that "OK" button. Acura should have it appear the first 100 uses or so, but after that, I think we all get the idea.
I hate the nag screen though.
You also don't have to press the OK button to have access to the HVAC controls. Just hit the A/C button on the dash, and it will bring up the HVAC screen - even if you have not hit OK.
Originally Posted by darth62
Just lower the temp on the automatic climate control. The system will increase fan speed to compensate.
Don't lower the temp if its cold out, it will decrease the fan speen.
Just busting your balls
I'm sure Acura's legal staff has told them that the nag screen has to always be there. The problem is that you might lend your car to a neighbor, or sell your car, or something like that. Acura has to make sure they are protected from liability each time somebody gets behind the wheel.
Speaking of which, does anyone know how to select the "OK" button without using the touch screen? I tried using the nav joystick like with the other buttons, but it didn't work for me.
Originally Posted by wsklar
Nav joystick works fine. Practice with Ms. Pac Man first, then try again.
... but I will try again when I return to school.
Man some of you people are getting lazy...
You guys want everything to work automatically. Maybe you should wait for the car that drives itself too.
I'm just hassling you Navi guys...
Sadly, all the automatic systems make it difficult to get do that.
Originally Posted by VeniceBeachTSX
That's great if you want to actually lower the temperature. More often than not I just want more ventilation into the car. In my climate, I rarely use much A/C or heat. I just want some outside ventilation without the windnoise that comes from opening the window.
Usually, I just set the vents to direct air at my face, allow fresh air in, and then everything is good. If I want more airflow, I vent the sunroof. Do you need to use the navi touchscreen to change the HVAC mode?
For some stuff you don't need the touchscreen (temp change, on/off, rear / front defroster)
It's a lame design flaw. The TSX is missing fan up/down and 6 preset buttons. That's 8 buttons in all it's missing. I don't have my TSX yet (hopefully tomorrow), but I am hoping that I can cope w/o these dedicated buttons.
These 8 additional buttons were 8 more reasons that I seriously considered the TL over the TSX, believe it or not...
Jon
Jon
Jon
Jon
I am surviving. You don't even notice they are gone. Plus the fact that you can just say "fan speed 4" is a lot safer then playing with buttons and it impresses the ladies...
When the nav screen shuts off on its own, all I have to do to activate the menu for the fan is to hit the A/C button. It does directly to the A/C screen and bypasses the disclaimer/OK button screen. I can also go directly to audio as well. The only time the disclaimer screen comes back on is if I choose nav.
one of my pet peeve of the nav...
I think Honda/Acura made the right decision in having the disclaimer screen and giving us full access to nav functions while driving.
Originally Posted by AlterZgo
The disclaimer screen is a PITA. But, I much prefer this compared to what other mfgs have. For Nissans and Infinitis, you have to bring your car to a complete stop before you can change nav functions. Imagine what a PITA it is if you're on the fwy and you want to change routes or something.
Otherwise, our last car (a Toyota Matrix XRS) had a Nag screen (push "Accept") and made you pull over. That really sucked!!!! Passenger could not even change anything, they would rather you pull off the freeway, change a setting, then get back on the Freeway. That is safer??? No
Summary, the Acura system Rules!!
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
4drviper
09-23-2015 09:00 PM
