Help with sub amp problem
Old Nov 24, 2011 | 10:59 PM
07tsx20's Avatar
i hooked up a kenwood 350 watt amp and a JL audio 10" sub in my 2007 acura tsx, it was sounding really good and i was getting it kinda loud but it wasnt distorting yet and all the sudden the head unit turned off it is a factory head unit non navi, it was just black and the climate control wasnt working either, i unhooked all the hookups to the amp and turned the car back on about a minute later the radio and everything turned back on, anyone have any idea what could have caused this because im kinda scared to hook my amp back up
Old Nov 24, 2011 | 11:12 PM
tsx_trendz's Avatar
whats the wattage on ur subs?
Old Nov 25, 2011 | 10:18 AM
07tsx20's Avatar
150rms, 400 max, it fits the amp perfectly
Old Nov 26, 2011 | 05:59 PM
sixwhip14's Avatar
How did you get the signal to your amp? Did you use a signal to line adapter? Also how did you hook up the remote to you amp?
Old Nov 26, 2011 | 06:53 PM
07tsx20's Avatar
i used an LOC for the signal and the remote is hooked up through th acc in the fuse box
Old Nov 26, 2011 | 07:34 PM
sixwhip14's Avatar
That is pretty much what I did. You could check to make sure the polarity of the subs are correct. You may just have to turn the gain down on your amp. I had a problem finding a 12v switched place in the fuse box for the remote. Had to hook up a switch to turn it off and on.
4drviper
Apr 23, 2025 07:13 PM
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
