Help! Small swirly scratches!
Old Mar 21, 2005 | 02:09 PM
TSXMike05's Avatar
Unhappy Help! Small swirly scratches!
Hey everybody. New to the post and owning a TSX. Loving it. Took delivery just before Christmas.
Just before we started to wash it for the first time in the full sun, my dad noticed that the hood had small little swirly scratches that are only visible if you look really closely. I thought nothing of it and washed it and figured it come right out.
Since then, I've been back to the dealer a few times asking what gives. They pretty much are telling me that it's probably windblown dirt or the way i'm washing the car.
I don't think this is the case. My dad & I are convinced that this was the dealer's fault when they made the car ready.
Does anybody have any experience this? Any help is appreciated.
Old Mar 21, 2005 | 02:11 PM
ClutchPerformer's Avatar
Welcome!
What do you wash your car with?
Old Mar 21, 2005 | 02:14 PM
GIBSON6594's Avatar
My Garage
What color is your car?
Old Mar 21, 2005 | 02:26 PM
TSXMike05's Avatar
Ok, to answer both questions. Color= Carbon Grey Pearl. I realize that more stuff will show because of the dark color.
I usually wash my car with one of those car wash gloves and rise the hell out of them between washes.
The point is that these swirls where there and still are pretty much after i took delivery. Am I being to picky?
Old Mar 21, 2005 | 02:28 PM
No you're not being too picky, but maybe you should have said something to the dealer before you washed it. The dealer will never admit to being at fault now. Sorry.
Old Mar 21, 2005 | 02:31 PM
slobeatz's Avatar
Littering and.....
If the swirl marks are all over the car, then it's probably from washing. Even if you rinse the mit well, it can still get particles in it while your washing the car. I suggest using Meguiar's #80 or Klasse AIO to get out the swirling, then top with a coat of wax. Also check out autopia.org for more information.
TSXMike05's Avatar
Yeah, isn't that clear coat sealant on the paint supposed to eliminate those small scratches or whatever?
I'm just so disappointed! Any recommendations on what I can do to reduce them? Wax?
Thanks everybody.
Old Mar 21, 2005 | 02:59 PM
jlukja's Avatar
Mequires NXT is supposted to fill in tiny swirl marks. Otherwise, you may need to polish it first, which should take the top layer (including the swirl marks) off and then wax it to put on a protective coat.
Old Mar 21, 2005 | 03:01 PM
TSXMike05's Avatar
But I still want to complain to that dealer!
Old Mar 21, 2005 | 04:29 PM
Originally Posted by TSXMike05
Yeah, isn't that clear coat sealant on the paint supposed to eliminate those small scratches or whatever? ....
Well, yeah. But you can get scratches IN the clearcoat, too (which is probably what you have). It's much better than scratches in the paint.
Follow slobeatz's advice and you should end up as good as you can.
Old Mar 21, 2005 | 04:30 PM
Dpak's Avatar
Loading...
go at night with steel mesh and vandalize all of his cars =]
Old Mar 21, 2005 | 05:29 PM
chingbra's Avatar
i had that same problem and i have the same color car as you. what i used was the zaino products. you can actually use any type of synthetic wax. to get out the swirl marks, i had to wash my car with regualr car wash soap. then i claybared it to get off all the left over particles. then i washed it again with dish soap. after that, i applied 2 layers of the zaino synthetic wax. it took me almost all day to do it, but it worked good. also, to prevent the swirl marks again, make sure you rinse the car off before you wash it. and never make circular motions when washing or waxing the car.
Old Mar 21, 2005 | 05:53 PM
TSXMike05's Avatar
Originally Posted by chingbra
then i washed it again with dish soap. after .
Thanks for the advice everyone. I've heard that you're not supposed to use dish soap on a car.
Is this correct?
Old Mar 21, 2005 | 06:30 PM
slats's Avatar
Very true! Anyone who says to wash a car with dish soap is a moron, no offense. It will strip your wax and dull the finish eventually. I'd advise you to wash, polish with Meguiar's #80 and top off with NXT wax. That should fix those swirls. Good luck to you.
Slats
Old Mar 22, 2005 | 01:53 PM
Is this correct?
That's correct. Dish soap is designed to cut grease (from pots and pans, etc.). But wax is essentially the same thing, so it destroys that, too. Chingbra's use was purposeful as he put on Zaino polish in the very next step.
Old Mar 22, 2005 | 01:58 PM
dom's Avatar
dom
We'll let this go but next time post in Wash & Wax
https://acurazine.com/forums/wash-wax-23/
Old Mar 22, 2005 | 02:03 PM
TSXMike05's Avatar
Well, i'm still going to swing by the service dept, just to see what they say. At the very least, I'll see about their recommendation for cleaners and stuff to see if they are up to snuff like you guys
Old Mar 22, 2005 | 02:04 PM
iamhomin's Avatar
04 remembrance
Detail your car with polish, then protect it with layers of Wax.
If lazy, just take it to some shop and let them do it for you for $100.
Old Mar 22, 2005 | 02:19 PM
TSXMike05's Avatar
Exclamation
https://acurazine.com/forums/forumdisplay.php?f=23
Sorry, I respect your authority!
So does that mean that this thread will be closed? I'm confused. ha ha
Old Mar 22, 2005 | 02:25 PM
jlukja's Avatar
domn's getting kinda honory since he's closing in on 15K posts. I wouldn't at :cop: I don't think it'll be closed, just a headsup that the next one will.
Old Mar 22, 2005 | 02:28 PM
chingbra's Avatar
the point of using dish soap is to strip the wax. you want the surface as bare as possible so you can apply the layers of synthetic wax. thats why you use the clay bar to make it squeaky clean. i agree that the dish soap can dull your finish if you keep using it, but not if you use it just this one time to remove the swirl marks
Old Mar 22, 2005 | 02:32 PM
TSXMike05's Avatar
To be clear, I wasn't at the authority, it was for me.
Thanks for the suggestion. I'm not comfortable stripping my wax on my fairly new car (only 6600 miles on it) because i'm not that experienced. What if i fark it up?
I appreciate all the input. Any other suggestions?
Old Mar 24, 2005 | 06:44 AM
TSXMike05's Avatar
Alright everybody. Im seeing the dealer today. Wish me luck!
Dad & I are still convinced that swirls were caused by buffer because they appear to be beneath the surface of the clear coat.
:cop:
Old Mar 24, 2005 | 10:17 AM
jlukja's Avatar
:cop:
Good Luck,
I don't think the swirls would be beneath the clear coat. If that is true then it really is a big problem because it means that the pain coat was applied incorrectly before the clear coat was put on. Swirls are usually just scratches in the surface of the clear coat which you can see when reflected light catches them. You can either a) fill them in using NXT or other similar product , or b) use a polish to "wear down" the surrounding area of the swirl and then put on a protective coat.
Old Mar 24, 2005 | 11:39 AM
TSXMike05's Avatar
Thanks James
The swirls are definately beneath the clear coat and it's all over the car. It appears that they muffed up the buffing then applied the clearcoat.
I'll keep y'all posted.
:cop:
Old Mar 25, 2005 | 07:11 PM
TSXMike05's Avatar
Cool
Update! Update!
I went to see the Sales Manager who is also the #2 guy in the dealership. He saw the little swirls and said that is below the clearcoat.
So, he said to bring it in on Thursday for their paint specialist to take a look at it.
Now, let's see what happens on Thursday
Old Mar 25, 2005 | 07:43 PM
jlukja's Avatar
Update! Update!
Its looking good for you then. Well, as good as it can seem considering that the paintjob seems to be defective. Good luck on Thursday
Old Mar 31, 2005 | 03:00 PM
TSXMike05's Avatar
Alright everyone, here is the update.
The guy that does the detailing and paint is a sub-contractor who shows up once a week. He does this work outside, so on a cloudy day, he would have missed these swirls.
Today was cloudy and ugly, so I decided not to get it fixed today and coordinate my return under full sun, so the swirls can be seen and fixed accordingly.
Btw, the dealership will cover the cost
Old Mar 31, 2005 | 04:15 PM
jlukja's Avatar
Good thinking
tsx_boy
Dec 13, 2019 08:33 PM
jsonkimz
Mar 28, 2016 07:49 PM
datadr
Mar 23, 2016 01:39 PM
lanechanger
Oct 13, 2015 10:56 AM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
