Harnesses for Stock Amp??
Ok, quick question:
I know you can use The Accord harness (part #08A31-0E1-010) for the "B" harness (the one that carries signals from the HU to the stock Amp).
Does anyone know what the part # is for the "A" harness adapter?? (this one carries the signal from the stock amp to the speakers, it is wider than the "B" harness).
THanks.
THanks.
yeah, i figured i could get it from the factory, but I was hoping someone could hook me up with the part # so I can try to find it online.
The parts dept is closed for the weekend and I am an impatient bastard.
huck - I am replacing the stock amp and would rather not have to hack into the existing harnesses.
I was going to use a 08A31-0E1-010 harness for an audio project (tapping in for AUX 3) but now I'm waiting to see what the Blitzsafe will do for me. Anyway, I haven't tried it yet, but that's the part # I saw online for an AUX hookup, not an amp hookup; it taps between the XM and radio, if I recall correctly, so you need the AUX 3 to switch between XM and your aux-in. I'm too tired to figure out if this is going to do what you want or not, but probably not? Dunno, but I hope this helps at least somewhat...
Moderator Alumnus
Please continue this discussion in here: https://acurazine.com/forums/audio-video-electronics-navigation-22/
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
xsilverhawkx
09-28-2015 06:51 PM
4drviper
09-23-2015 09:00 PM
