front lip only or full kit
Does it look good or bad to only have a front lip on the 04-05 model.
Is it better to have a full oem kit?
Anyone have pictures of the car with only the front lip install from different angles?
Comments and pictures are most welcome
thanks
thanks
Let me help you!
Some people only go with the front since it's the one that's most noticeable. However, it is a lip kit, which means it's added to the edge (ie: it'll lower the height of the lip). So if you look at it, you'll see the front lip at one height, and your side/rear higher than that height. If you don't mind it being uneven, then go ahead. Most people want the height to be the same all around.
boost owns
Full kit. Go big or don't go at all. Cars with only a front lip on look very unbalanced when you see them from the side, and it just looks wrong to me.
Save up a bit and do it right.
I have just the front lip for several reasons. Like someone said above it does not make a big difference to have the who kit. Im saving weight and I like the look with just the front lip.
Check the link: http://www.cardomain.com/ride/2247067
resident asshole
Originally Posted by Newplay1
This is not so good example of having just the front lip because its taken next to this friggen hook'd up MUGEN with 19s Volks black TSX.
ASM 3G TL Type-S
boost owns
Originally Posted by TommySalami
Isn't the front bumper a bit higher than the side of the car? So a front lip would even things out?
I was thinking about just getting the front 06+ Euro R lip
envision this extreme...getting a mugen lip or even a mugen front bumper and leaving the sides and rear stock. it is a kit for a reason, it all flows together.
ASM 3G TL Type-S
Originally Posted by CGTSX07
Getting just the front lip would actually uneven things out. the front would hang lower and would not look proportioned when looking from the side.
I accutaly like how the body lines flow from back to the front,
Originally Posted by Audioserf
You know, I take back what I said. There are some instances where a car can look great with just the front lip. Yours is one of them.
handsom-hustla
11-13-2015 05:04 PM
Pegon95
08-31-2015 02:18 PM
