Faster light signals?
I've been researching on how to make turn signals quicker than how it is in stock. I know people in sometime of there life that have seen those ricegrinders with turn signals that goes about 10 signals per seconds..etc...
How is this possible to do in 06 TSX?
In all fairness, I find most cars to have a slow default setting for signal delay. The problem is fairly noticable at highway speeds. I think someday turn-signals will be speed-sensitive, but not yet.
If you are sitting still, and the car in front of you is sitting still and the blinkers flash 1 time per second how is that different then if you are on the high way going 65 and the person in front of you is going 65?
This sounds like the 'every car should have turn signals in the side mirrors so others can tell when I'm coming over' arguement. If the turn signal is flashing too fast maybe the actions you are taking at highways speeds are too sudden. You should always signal BEFORE changine lanes, not as you are doing it.
Let me help you!
I used to want to this on my accord, but the urge has left me. It does look annoying eventually. I also noticed that the turn signals are bright...I always see my turn signal lighting up the street signs while I'm waiting to turn (in my tsx), so having it flash quicker would probably annoy the whole intersection...
Other than annoying people, I suppose there might be other consequences. Faster light signals means more time spent in the on position, and perhaps burning out sooner. I know not that much sooner, but it's an idea. Also, if you have a big stereo system, you might need to take into account the power draw.
(I'm just trying to convince you not to do it lol)
ROFL, when I was in my rice-mode back in college I had a high-speed flasher relay and a brake impulse relay. The flasher was a Latin-beat blinking pattern, the brake impulse would flash 4 times then stay on and you could control the speed as to how fast each blinks with a dial. Both relays were Japanese products, instructions all in Japanese and you might be able to find them on ebay.
Ah the memories of being a ricer!
Fast blinkers were cool during the early 90's.....![Rice](https://acurazine.com/forums/images/smilies/rice.gif)
Then again, so was wiring your signals to they stayed on (aka "ambers"). When I bought a Mitsubishi Eclipse, I felt left out because my rear turn signals were red.
If you're going to do it, might as well complete the look with a neon light under the car.
![Cry](https://acurazine.com/forums/images/smilies/cry.gif)
sockr1
10-01-2015 01:31 AM
Greengecko
09-16-2015 08:19 PM
