Exceeding the Maximum Payload in a 2004 TSX
Old Dec 29, 2009 | 01:16 PM
dannyw68's Avatar
5th Gear
Hello everyone,
I know that the max payload of the TSX is around 850 lbs, but I need to move 1000 pounds of lead shot in individual 25 lb bags. Including, my own weight, the total car payload will be around 1200 lbs. If I distribute the weight evenly in the truck and on the floors in the back and the front seats, do you think this will cause any problems. The car is rated to tow 1000 lbs, so I dont think there will be any engine or transmission issues. But it may be low riding a little. What do you think?
Old Dec 29, 2009 | 02:26 PM
curls's Avatar
Someone stole "My Garage"
Depends... how far do you have to drive like this? You will be riding low (very low) and likely wearing the tires down very quickly as the toe angles change under that much weight.
Can you take it in two trips? Even though it's more for gas money, it'll potentially save you problems later on (not to mention be easier to load the bags!).
For what its worth, I moved 10 boxes (40 lbs each) of laminate flooring, and while I am lowered on stiffer springs, the car rode VERY low under this weight (distributed in the rear seat/trunk area), and turning was almost impossible on wet roads. Acceleration was scary-slow (dangerous) again due to the damp roads. That 400 lbs is only about 40% of the weight you want to move. I would NOT recommend it.
Old Dec 29, 2009 | 07:45 PM
nbtx's Avatar
still plays with cars
Add a couple PSI to each tire and drive conservatively. Since I don't know where you are, I can't report you to the over-weight police ...
Oh, don't expect that cardboard in the trunk to support much weight.
Old Dec 30, 2009 | 09:30 AM
litesout's Avatar
Oliver!!!
Yeah, I'd put something down in the trunk otherwise you'll likely collapse the fiberboard in the middle. Spread it out along the floorboards and trunk and you should be fine, but I wouldn't recommend driving too far on it.
So, 40 bags, huh? Doing a little reloading, are we?
Old Dec 30, 2009 | 11:35 PM
fast1's Avatar
I had about 300 pounds of cement (premixed of course) and it totally changed the driving character of the car in a negative way. My rear wheels were nearly on the wheel arches... fortunately it was less than a couple of miles on slow roads I had to drive.
Old Dec 30, 2009 | 11:50 PM
fast1's Avatar
GVWR (Gross vechicle weight rating) is what you need to worry about. I think that number until 2009 was 4300. The 850 is a good ballpark number to use for the max lead and you that you should put in. Make sure you put that weight in even and bump up your tire pressure 5-10 psi to prevent your tires from flat spotting.
Old Dec 31, 2009 | 12:02 AM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
If you exceed the maximum weight for a short period of time, I don't think you have anything to worry about. But, your braking distances will be longer. That's one thing you have to worry about.
Old Dec 31, 2009 | 08:55 AM
curls's Avatar
I still stand behind my recommendation to take TWO trips. Its safer in all respects, period.
tsx_boy
Dec 13, 2019 08:33 PM
navtool.com
Sponsored Sales & Group Buys
87
Jan 23, 2016 01:25 PM
GWEEDOspeedo
Jan 15, 2016 10:39 PM
ceb
ILX
Sep 27, 2015 10:56 AM
TLguy42
Sep 26, 2015 11:27 AM
