Electronic Rust Module
Old Jun 5, 2006 | 11:41 AM
PearlWhite05's Avatar
Final Coat Rust module, shoots out currents through the entire car to prevent oxidation and slow the rusting process down. http://www.capfinalcoat.com/
Anyone has it? is it effective? Does it really work, if so it is a lot cleaner and can replace drilling holes and spraying your car every yr.
Theres already 1 Acura dealership that sells this.
Old Jun 5, 2006 | 11:50 AM
06blkbeauty's Avatar
8th Gear
Old Jun 5, 2006 | 12:39 PM
narci's Avatar
Canuck
If the Acura dealership sells this, ask if they will give you a 10+ year warranty for rust on the body. I want to see if they will back up what they sell.
Old Jun 5, 2006 | 12:43 PM
CGTSX2004's Avatar
If it sounds too good to be true, it probably is...
Old Jun 5, 2006 | 02:29 PM
jpt's Avatar
jpt
I do believe our car won't rust in any significant places if you get this.
Then again, I do believe our car won't rust in any significant places if you don't get this, making the purchase, um, less than extremely valuable
Old Jun 5, 2006 | 03:50 PM
sauceman's Avatar
Moderator Alumnus
I'm really a n00b when it comes to electricity, but doesn't the ground on the battery already do this?
Old Jun 5, 2006 | 05:03 PM
so everyone sprays? I live in Toronto where the winter is harsh, lots of salt
Old Jun 5, 2006 | 05:09 PM
rmpage's Avatar
Drives With Hands
Cathodic protection is real. It is normally used on things like the hulls of ships, underground pipelines, offshore drilling platforms, bridge pylons, etc. Anything that will be immersed in a corrosive environment for a lengthy amount of time gets it.
This is the first time I've seen it applied to a car though, and I'm having trouble understanding why they claim to use a small AC voltage in this case rather than a low-current DC source, which is what CP usually relies on due to the fixed electronegativity of steel (or whatever you're using).
If they can give you some kind of guarantee in writing, though, I say go for it. It can't hurt, and that little driver box sure as hell better not cost too much either.
Old Jun 5, 2006 | 05:28 PM
absolude's Avatar
Electronic rustproofing only work when the "subject" is submerged. They do nothing for cars.
FTC Ruling Regarding Electronic Rustproofing
In March 1996, the U.S. Federal Trade Commission (FTC) ruled against claims for an electronic rust product called "Rust Evader." The product, that connects to the vehicles battery under the car hood, was claimed to prevent rust in autos through cathodic action. The FTC ruled that the Rust Evader Corporation deceptively represented salt-water demonstrations and other tests as proof that the product would protect motor vehicles from corrosion. Then-president David McCready was barred from future use of the names "Rust Evader" or "Rust Buster" for this or similar devices and from claiming that they prevent automobile corrosion.
Old Jun 6, 2006 | 06:55 AM
Absolude, did you check this website www.capfinalcoat.com Its not from Rust Evader Corp or Rust Buster. They garantee no rusting from the "inside" out whatever that means.
Old Jun 6, 2006 | 09:49 AM
joerockt's Avatar
Just dial 1911
I bet you get better gas miliage with this as well...Sign me up...
Old Jun 6, 2006 | 11:21 AM
Can we get away without rust proofing our cars? For those who live in places that have long winters too. Rust will occur naturally but as long as its not all over and in large spots, I can live with that.
Isn't our cars coated when manufactured?
CL-S progression 01
Jan 26, 2016 04:15 PM
lanechanger
Oct 13, 2015 10:56 AM
SUPRMN84
Oct 7, 2015 09:46 PM
polish_pat
Sep 30, 2015 12:22 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
