Educate me on Basic Engine Mechanic - RPM
Old Jun 22, 2004 | 08:57 AM
robert_tsxgeek's Avatar
Need some basic mechanic education here...
I may be mistaken but I've always had V6 until TSX....
At the same speed...V6 RPM is LOWER than 4-cylinder , correct ?
I have the impression that given the same horsepower, LOWER RPM is a good thing,
good for engine wear, for fuel eco., correct ?
I kept hearing TSX being called "high-revving" --- is it a negative thing ? why ?
Basically my aim is to keep engine in top shape & ensure durability, I am willing to trade that for speed & power....so now I am consicously limiting RPM to 2K which get me up to 60 MPH....silly ?
Old Jun 22, 2004 | 09:09 AM
rb1's Avatar
rb1
RPM is not necessarily related to engine size, its more related to gearing. Your gears multiply the engine torque to make the best use of your engine power. Even a car with a 400 hp engine wouldn't accelerate particularly fast without gears.
Since typically a 6 cylinder engine offers more torque and horsepower than a 4 cylinder, less "gear multiplier" (technically "mechanical advantage" is the term) is needed, so yes a 6 cylinder generally operates at a lower RPM (in the same gear and vehicle speed) than a 4, but again this is strictly a function of the gears.
There are pros and cons of designs oriented toward both high and low RPM operation. High RPM is typically associated with more noise, fuel consumption and (in the very long term) valve-train wear. Of course, when you have a 4 cylinder engine, the increase in fuel consumption is offset by having fewer cylinders. A 4 cylinder motor would have to run 50% faster (all other things being equal, which they rarely are) to consume the same gas as a 6 cylinder engine. More typical is for the 4 cylinder to be geared to run, say 25% or so faster, so you come out ahead fuel-wise.
Low RPM operation typically means less pep, since by general implication you are in a "taller" gear (again, less mechanical advantage). Low RPM engines have less valve-train wear but more cylinder and ring wear, since it must supply more power per engine stroke.
Personally, high RPM engines (e.g. typically 4 cylinder cars) are generally much more fun to drive, since you get to experience greater ranges of engine operation while operating at legal speeds (at least pseudo-legal). Also, on the highway a 4 cylinder engine is almost always in the meat of its power-band and generally fairly responsive. Low RPM gearing requires downshifting to get into the power-band.
EDIT: Oh, one more thing. Honda/Acura engineers their cars for high RPM operation. Few engines sound sweeter than an Honda motor running at 4000-6000 RPM, so live a little...
Old Jun 22, 2004 | 09:12 AM
iamhomin's Avatar
04 remembrance
Speaking of fuel consumption, correct me if I'm mistaking.
A 2.4 Liter engine reving at 3k is equivalent to a 3.2 Liter engine reving at 2k, right?
Old Jun 22, 2004 | 09:14 AM
rb1's Avatar
rb1
Yes, if you really meant to say a 3.6L engine with all other things being equal. It's not the same if the 2.4L engine is running under light throttle and the 3.6L engine is running WOT, or vice versa.
Old Jun 22, 2004 | 09:17 AM
elduderino's Avatar
VP Electricity
No, RPMs are RPMs... driveshafts spinning translates into wheel speed.
But with more cylinders, engines are much more likely to have more power at lower RPMs. When Honda engines are referred to a "high-revving", it means that they "like" to rev high because that's where they develop power. (It's actually their owners which are "high-revving".)
Here is a chart showing HP by RPM of a TSX 4-cylinder motor. Make sure to look at the baseline, not the modded line.
Here is a dyno chart of a 3.2TL motor. Note the different shape of the curve? More percentage of the potential horsepower is available relatively lower in the RPM scale?
That's what it means...
Old Jun 22, 2004 | 09:46 AM
elduderino's Avatar
VP Electricity
And get off the 2K limit... just stay short of the red line, and change your oil.
Old Jun 22, 2004 | 10:46 AM
thanks for sharing your knowledge, elduderino, very informative
Old Jun 22, 2004 | 12:06 PM
TSX Cman's Avatar
yea. i rev the hell out of my car ( the intake makes it tempting all too often) . much more enjoyable. if you drive casually, rev it up as high as you please, drive smooth and you shouldnt even notice too bad of milage. i shift at 3000-4500 casually. and pass 6000 often as well.
Old Jun 22, 2004 | 01:21 PM
gfxdave99's Avatar
6MT Snob
Could you go into a lil more detail about the difference the intake makes.. is it mainly an aural (sound) improvement or do you really feel the diff? and can you hear vtec kick in more?
Old Jun 22, 2004 | 04:24 PM
kaikai114's Avatar
Got Milk???
:phatyo:
Sep 14, 2015 10:09 PM
merc009
Sep 14, 2015 06:43 PM
Sep 14, 2015 03:16 PM
Billu99tl
Sep 13, 2015 11:30 AM
ninersfgiantsfan
Sep 9, 2015 01:14 PM
