Ebd
Old Dec 17, 2003 | 10:01 PM
darth62's Avatar
Not an Ashtray
Ebd
This is what Consumer Reports had to say about EBD at their website:
"Virtually every car can compensate braking according to load. It's not new. It was true even in the 70s"
Basically, they see EBD as feature that is of minmal utility. I'm only raising this issue because this is one feature that the TSX does not have, which other upscale sport sedans do. I had wondered whether the TSX's so-so braking preformance might be partialled rooted in the lack of EBD.
Old Dec 17, 2003 | 10:55 PM
Test_Drive's Avatar
Hmmm, that's a very interesting conclusion that CR has come to. I have theorized myself, that lack of EBD contributed a bit to the longer-than-you-expect stopping distances.
In dry, high-grip situations, you'd expect the majority of braking force to come from the front tires.
In wet/snow/ice low traction, you'd expect braking to be roughly 60/40, following the car's weight distribution.
...I think I'm going to have to go over there (CR) and read that article that you were talking about. Do you have a link? (I have an online subscription).
Thanks,
Test_Drive
Old Dec 17, 2003 | 11:43 PM
darth62's Avatar
Not an Ashtray
Thanks,
Test_Drive
Yeah, this was in the Discussion section. One of their editors responding to a questions from a poster. I think he was comparing a M6 to a TSX:
How beneficial is Electronic Brake Distribution? I noticed EBD is not listed on the CR Model Overview profiles. However, antilock brakes, traction control, and stability control are included as part of the safety feature criteria. How much does this feature typically add to the cost of a car?
I am considering three cars that cost less than 30K and that are equipped as shown in the chart:
ABS X X X
4-Wheel disc X X X
EBD X X --
Traction Control -- X X
Stability Control -- -- X
Assuming these cars are comparable in most other respects that are important to me, which is likely to be the better choice?
Thanks,
Charles
To: C._Charles (2 of 3)
156.2 in reply to 156.1
Virtually every car can compensate braking according to load. It's not new. It was true even in the 70s.
The car in your right column has the most comprehensive safety equipment due to the stability control system.
Options Reply
To: CR_Expert_Gabriel (3 of 3)
156.3 in reply to 156.2
Thanks Gabriel!
It is such a blessing to have access to impartial expert such as you to help cut through all the marketing hype that adds to the confusion of the car buying process.
How much is typically added to the cost of a car for this "new" feature?
Charles
Old Aug 26, 2004 | 05:05 PM
scheißterhöffer's Avatar
Was wondering about this. TSX does not advertise EBD as a feature, but on page 213 of the manual (The Braking System), center column, third paragraph, it says:
"The ABS also balances the front-to-rear braking distribution according to car loading."
What is this, if not EBD?
Old Aug 26, 2004 | 06:26 PM
jcg878's Avatar
Obnoxious Philadelphian
wow, good find
edit: I have now bumped you to block #2
Old Aug 26, 2004 | 06:32 PM
Schweet. Finally I have risen above all the other one block savages here on the site. May you all burn in eternal hellfire!
Old Aug 27, 2004 | 03:58 AM
sauceman's Avatar
Moderator Alumnus
Old Aug 27, 2004 | 04:01 AM
biker's Avatar
wow, good find
Just for ?
Old Aug 27, 2004 | 10:17 AM
jcg878's Avatar
Originally Posted by biker
Just for ?
Yes. I but didn't remember that
Old Aug 27, 2004 | 11:16 AM
ClutchPerformer's Avatar
is good!
Soul_Deamon
Nov 13, 2018 04:44 PM
BOOSTED6IX-S
Feb 22, 2016 01:53 PM
Sun Diego CL-S
2G CL Photograph Gallery
22
Jul 27, 2007 02:10 AM
REV-01
22
Nov 23, 2004 04:23 PM
