Drove RDX today....
Drove RDX today....
And I gotta tell ya, that thing is dope. I was not too nuts about the exterior design to begin with, but the interior makes it all worth while. So fresh. So clean. And plenty Acura refinement. As far as the handling and ride...I think it would handle better than a stock TSX in some corners to be honest with you. It's tight as hell. The Turbo is nice too....it may out run a stock AT TSX as well. Not sure of any real specs however, these are just my initial impressions. The coolest part...the reverse cam! When you put the bitch in reverse, a camera feed from the rear hatch displays on the Nav screen so you can see exactly what is behind you. Certainly a nice touch. Overall...it's definately THE x3 killer.
Oh yeah!!!! Also ended the day by getting the g/f out of her 2002 civic and into a 2007 Volvo S40. Red on black 2.4i, loaded, for $265/month for 36 mos!!! Hella good deal. She's actually at $10 less a month than she was with the old and busted civic!! So today was a good day overall!
Time to Climb
i'm not big on suv's nor am i too fond of the rdx's exterior design. however, i'm very much interested in the rdx's 2.3L turbo and sh-awd - at least to the extent that it relates to transferring to future tsx models.
mrgold35
Its not saying much about the RDX if: "The Turbo is nice too....it may out run a stock AT TSX as well."
My son on his on his Razor scooter can almost out run me in my 06 5AT.
I was expecting the RDX performance to be between the 5AT/6MT TL range, not the TSX range.
If you look at the specs, the TSX and RDX have almost exactly the same power/weight ratio. I would expect similar performance out of them (of course the SH-AWD is going to zap some of that power though).
The RDX has 6.12 Horsepower/100 lbs.
The TSX has 6.11 Horsepower/100 lbs.
That is peek horsepower too.
Originally Posted by zidenx
the reverse camera is nothing new, the mdx has the same feature.
Originally Posted by Tsx536
Yeah, tell us more about the engine power. What did you think? Any lag? Did you get to gun it, or was the salesman trippin?
Originally Posted by EuRTSX
Might want to watch out for those new S40's built by Ford. My brother has the 2005 S40 T5 AWD, and it's been having a lot of annoyances lately.
Exterior styling-wise, I think the new Mazda CX-7 is much better looking than the RDX and the Mazda costs thousands less. The Canadian Acura Expression magazine has an article on the RDX. It says pricing should start in the low 40's CND.
The interior of the RDX does look nice though. It reminds me of the dash from a Land Rover.
Bye TSX, hello domestic?
Rep'n Taxbrain.com
Nice find Jan!
They have another video with the modded TOV Si. (Bottom of the page):
http://www.vtec.net/articles/view-ar...icle_id=599611
mrgold35
"With the variable flow turbo (VFT), Acura has devised a simple, yet elegant solution for reducing turbo lag. At low rpm, a long valve smoothly narrows the incoming passage and speeds the exhaust flow. This keeps the turbine spinning quickly, so there is plenty of turbo boost at low rpm. As rpm rises, the valve opens, allowing the increased exhaust volume to flow freely through a second intake chamber, keeping turbo boost high. The forced intake air is cooled through a top-mounted intercooler, making the air denser and allowing it to burn more powerfully. The result is the instant and steady power delivery of a much larger engine, while retaining the light weight and cruising efficiency of four cylinders."
I hope they use the VFT for the 08 TSX.
Rep'n Taxbrain.com
Originally Posted by Zoopa
That's great, but I'm on the TSX forums because I like cars.
From the ACURA RDX web site
EGT's (exhaust gas temps) are so high on turbo gasoline engines (e.g. versus diesel, which is much cooler) that I would worry about long-term reliability of any variable-geometry setup with a gas motor. The exhaust side of a gas motor turbo can easily get red-hot during extended aggressive driving.
As an aside, another cool way to achieve the same effect is with a VVT (Variable Vane Turbo), but again I think gas EGT's are too hot.
She said: it's GINORMOUS!
calling JTso...
when honda puts the 2.3T on the TSX, *cough*JTso*cough* needs to rig up a water injection system on the intercooler.
so everytime we downshift on the paddles, it squirts to cool the air *hint hint*
This very much relates to cars though. The RDX has Honda's first turbo and it's destined to be put in a car soon! Hopefully a TSX
They could skip the AWD and just do RWD and save weight, complexity and gas mileage. He he!!
