Drive+play and iPod Integration for 2005 Navi
The Drive + Play isn't designed for integration into the factory system. Its designed to use the controls and screen that come with it and transmit the audio through the factory system. If the 05 has XM you can get the iSimple. I've got one in my 08 and it works great. Gives me text and allows me to use the steering wheel controls and everything.
for the .26 firmware:
In the top display it will say "XM Loading"
The unit does not initialize properly about 40% of the time when you start the car, therefore the radio modes must be cycled through before it works properly.
The gain for the volume is noticeably lower than CD quality sound.
This has been confirmed by Tony (a rep for the isimple). He has stated that the iSimple has not been FULLY tested in the TSX.
Once Tony sent me the right firmware for it, it seems to work fine. The volume is lower than CD, but the controls seem to work fine. To be fair, mine's only been in for maybe a week now, but its been flawless.
Hi All,
Thanks a lot for your inputs..
As i got the Wired FM Transmitter along with Drive+Play i am thinking of using it to connect my iPod/Zune (for that matter any Mp3 Player) . I know with this i won't be able to use the Audio controls in the Nav or on the Steering columns..That's fine with me..I am primarily looking to plugin my iPod into the Factory audio instead of using the ear phones..
I contacted the Harmon Kardon reg plugging the Wired FM Transmitter and i might need to get one of the Antenna Adapter
http://www.installer.com/item/displa...php?it=40-hd20
Mars..
Mars..
4drviper
Apr 23, 2025 07:13 PM
lanechanger
Oct 13, 2015 10:56 AM
us285126
Oct 2, 2015 02:03 PM
Joe Avesyan
Sep 29, 2015 03:57 PM
TLguy42
Sep 26, 2015 11:27 AM
