Downshifting in SS Mode
Rep'n Taxbrain.com
I was just wondering if you guys who have 5AT downshift usually instead of using the brakes when you're taking turns/corners in SS mode.
Is it bad for the car/transmission to constantlly downshift instead of using the brake turns? I'm wondering if there are long term effects..anyone have any ideas?
![Ponder](https://acurazine.com/forums/images/smilies/ponder.gif)
NBP/EBONY/6MT
My
: brake pads are a lot cheaper & easier to replace than a transmission (or the clutch in my case), so I would use your bakes instead. Its definitely less wear on your transmission, I just dont know how bad the other way is.
Im 99.9% in SS mode, so I do this alot, Tranny seems to be fine, need some brake work now though, Cars almost 2 years old so makes sence, prob some new pads and sand down the rotors....would love to put on some slotted ones but Im pritty much broke now...
Downshifting in SS should cause no more harm, short-term or long-term, than downshifting a manual transmission (perhaps less since you cannot over-rev an engine in SS mode).
The SS in the TSX is terrific (other than the direction). Downshifting will allow better control in curves than using brakes. It can also reduce wear on the brake pads and rotors -- as well as reduce the probability of warped rotors. I am 98 percent SS and will commonly downshift hundreds of times a day. It is very unlikely that I would buy another car without some form of SS.
Being a FWD, and by nature a car that pulls rather than pushes, it helps to navigate a sharp curve by being in a lower gear, and applying some throttle, at the apex of the curve. The SS complements the suspension on the TSX.
Reversing SS
Originally Posted by LannyM
It is my contention that Acura could add a jumper, or a switch, under the shift gate for less than a dollar a car. Then, they could then make replaceable shift gates (apparently made of plastic) available for $10.00 -- $25.00 USD and have one more edge up on the competition -- as well as making more customers happier. A dealer could do the switch for around $50.00 USD (including parts) and make money on it. It would also look original. I would pay the $50.00 in a second.
What is really strange is the SS in the C Class Mercedes. You tap it left and right, rather than forward and backwards, to change gears.
I imagine it gets to be fun for the salespeople, and service people, when some vendor decides to make a wholesale change to the direction of the shifter.
Obnoxious Philadelphian
Well I'm probably 10-20% SS, but my main use of it is to hold the car in the correct gear before a turn to accelerate out of it (or to drop into a lower gear to pass someone so I don't have to wait for the tranny to do it on its own). I'm not worried about causing any damage. If it does, it'll be the last auto I ever get, cause I'd be miserable without this capability.
Originally Posted by jcg878
... (or to drop into a lower gear to pass someone so I don't have to wait for the tranny to do it on its own)...
I feel the need...
I can't believe we don't have a powertrain engineer on this forum to chime in. Seems to me that it's common sense: the more you upshift/downshift a transmission the more wear and tear is occuring...especially if you have a habbit of downshifting into the higher rev ranges.
I'd much rather replace front rotors/pads than a new transmission...since I plan on keeping this car for a while. On the flip side, I did purchase a sports sedan...if I just wanted a smooth ride and poke along like Grandma - I'd buy an Avalon.
PistonFan: who loves taking freeway merge ramps at twice the posted speed...and watching another soccer mom who was previously riding my ass in her honking suv dissapear in my rearview.
Originally Posted by Tsx536
..Is it bad for the car/transmission to constantlly downshift instead of using the brake turns? I'm wondering if there are long term effects..anyone have any ideas? ![Ponder](https://acurazine.com/forums/images/smilies/ponder.gif)
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
Old fart
Another big benefit to the Sport Shift. I use it often for passing since having the car in a passing gear a couple of seconds before you pull out into the other lane reduces the time needed to pass. It is beneficial, even on multilane roads, when there is traffic in a left lane and you need to "step on it" to get around someone in front of you without holding up the traffic in the lane to the left. I will usually drop a gear or two, and start accelerating, before I change lanes.
![Nod](https://acurazine.com/forums/images/smilies/nod.gif)
and on a side note, like what CG said, I let it downshift itself to 1st when coming to a stop.
Rep'n Taxbrain.com
Cool....guys..thanks for the input. I wasn't thinking it would cause damage, but I wanted to see if others felt the same. I do use the brakes when I wanna stop and I just let it downshift also. My question was really geared towards when you're takin some corners and tryin' to pass.
I just got an Injen intake...so I've been downshifting a lot lately since most of the power is in the mid/upper RPM range. Just wanted to be make sure I wasn't F'in my tranny up.
So do you guys think constantly downshifting does put a lot more wear and tear on the transmission?
I know that the computer also downshifts, but it controls the transmission electronically instead of manually like when we use the sport shifter. Things that are mechanical seem to wear out faster than things that are electronic/software driven.
I would say that it is safe to use the Sport Shifter as much as you like; but try to keep the RPM's below a threshold. For normal driving, my threshold is 4,000 RPM's. On steep slopes, my threshold is 5,500 RPM's. Above that, and I start using brakes.
Originally Posted by STC
why didnt you get a stick instead then?
oh well...SS is still fun...and My Mustang...whenever i get it will be a stick...
I don't think there is much difference between the computer determining when to downshift and you determining when to downshift as far as the transmission is concerned. When you are using the Sport Shifter, I believe you are sending a signal to the computer. The computer, in turn, sends a signal to the solenoids in the transmission to effect a switch in hydraulic pressure causing one clutch to release (the current gear) and another clutch to engage (the new gear). In automatic mode, the computer takes it input from several sensors to determine the shift points. Otherwise, it is about the same.
You are not physically moving anything with the SS - just asking the computer for permission to shift. It still considers whether your suggestion is safe or not, it just gives some leeway.
3rd Gear
I also have a new '05 auto with SS. My question is when shifting in manual mode, do you guys take your foot off the gas pedal inbetween shifts like a regular manual or keep foot on during the shifting?
Originally Posted by migs
I also have a new '05 auto with SS. My question is when shifting in manual mode, do you guys take your foot off the accelertor inbetween shifts like a regular manual or keep foot on during the shifting?
Biggie_B
02-26-2017 11:14 AM
