Downshifting on AUTO
Old Apr 23, 2004 | 12:51 AM
jdm_ack's Avatar
ive been avoiding cops at high speed by downshifting on auto. couple of my friends told me that it would ruin my transmission. would it ruin my trans?
Old Apr 23, 2004 | 12:57 AM
slo007's Avatar
Master in Science
Re: Downshifting on AUTO
You mean by using the sport shift feature? I hope not because I do so in the off ramp to my place every time... 80 to 25 mph in less than 10 secs (also using the brakes a bit)! After the posted-20-mph-turn, I put the gear to Drive and on I go.
Old Apr 23, 2004 | 12:58 AM
CGTSX2004's Avatar
If you're using the SS and it doesn't over rev, you should be fine. However, instead of downshifting, try using the brakes next time. They are much more effective at slowing you down.
Old Apr 23, 2004 | 06:32 AM
biker's Avatar
Using brakes is a lot more cost effective and does a better job slowing you down than the tranny (be it MT or AT).
Old Apr 23, 2004 | 08:21 AM
DEVO's Avatar
you will not ruin your transmission. using your brakes with engine braking is the safest way to slow down your car.
Old Apr 23, 2004 | 09:50 AM
Chuck091279's Avatar
A Saitama Garage
I do this too every now and then. Is it bad? I was always taught that it's more economical to slow down a 5spd car using the transmission and downshifting rather than applying brakes, b/c energy is lost when you hit the brakes. Is that true? Also isn't downshifting supposed to be better for gas mileage?
Old Apr 23, 2004 | 10:29 AM
biker's Avatar
It's not any more economical - especially if you blow your tranny downshifting. Energy is lost no matter what you do to slow down. The only time this applies is on a hybrid car that uses the motor part of an IMA system to recharge the batteries.
Downshifting does not save gas. It gets you in the proper gear/power band the next time you need to accelerate.
Old Apr 23, 2004 | 11:43 AM
slo007's Avatar
Master in Science
I think so, too. Yet I always keep the RPMs under 4500.
Old Apr 23, 2004 | 01:00 PM
Mighty1's Avatar
Powered by Hondanium
Engine breaking is a useful tool, especially in bad weather. On downhills in slippery conditions engine breaking can give you better control when decelerating. You're still better off using the brakes as your primary way to stop/slow down, that's what they're there for.
Old Apr 23, 2004 | 01:34 PM
forestsoft's Avatar
TSX-Black Bolt
I down shift all the time, I live in the foothills...
I lightly used the brakes in the hills.. coasting down hill , while in lower gears, and down shifting when needed...this is the norm for me.
No issues yet...6500 miles on it.
Old Apr 23, 2004 | 03:28 PM
ecsw's Avatar
Do both downshift and break all the time. As long as the RPM is not too high, it should be ok.
Old Apr 23, 2004 | 04:58 PM
corbs's Avatar
Baka Unco
I think the reason he's not using his breaks is because the "cops" he's been avoiding would see the brake lights. The police often take the break lights as an admission of guilt. . . if you weren't speeding why'd you slow down. . .
Old Apr 23, 2004 | 07:02 PM
tsXgtp's Avatar
Sile
Downshifting is fine for it. Keep it under 10mph when you go into first. That is the main concern (1st gear).
But why put it back in auto after downshifting? Keep it in SS =)
Old Apr 23, 2004 | 10:21 PM
kiteboy's Avatar
The AT-SS will prevent downshifts into a gear that overrevs the engine. The gear indicator just blinks a few times.
Mike Pilipenko
Mar 26, 2024 09:21 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
malvothegreat
Sep 29, 2015 12:38 AM
jmaxima03
Sep 27, 2015 10:22 AM
