Does the air filter actually do anything?
I drove through a few flies ( I saw them clearly because of the hids) and one came straight out the front vents
If a fly can make it through, then how is it supposed to filter out pollen and dust
send me a link to JDM??
you better check that your filer is on correctly and there isnt a hole in it... cause that's just not good
maybe he flew in through the exahust pipe
You mean the pollen filter, right?
check your filter. you can get pollen filter removal instructions off www.vtec.net (same as 7 gen accord). I just replaced mine, it was so disgusting, charcoal black and 100s of flies and lots of dirt.
http://www.vtec.net/articles/view-ar...icle_id=355466
My'00 S2000 has one too, but I've never replaced it. Seems pointless in a convertible.
HOWARD911S
this thread reminded me of a guy i knew. he had an eclipse and he TRIED to do ram air on it by..........extending the air intake type. REMOVE the air filter and remove the air box............. he freaking put a T shirt over the tube. used rubber band wrap it down.. and spray damn K n N oil over it. thinking that will be the least restrictive and the K N oil will protect his car.. WRONG!!!!!!!!!! his car died a month later. muahahahhahha
Seriosuly, I once took my previous Civic for a 15k or 30k maintenance checkup (at a Honda dealership) and when I got it back it sounded a bit louder but being kid I didn't bother to look right away. It was at least a week or two before I saw they had disconnected the tubing that runs from my airbox to be throttle body and left it that way. It was disconnected at the airbox so my car was running on totally unfiltered air all that time! Well, that car never gave me any engine trouble -- that is until the water pump seized up and broke my timing belt (with 88k miles) just ONE day before I was trade it in and take delivery of my current Civic. It could have been worse though; no engine damaged was done and I got it all fixed for around $200 (that's 1995 dollars).
Ya but how does a fly get through? I dont know if I want to spend $50 to replace it if its useless.
Well... if you bought the car used... maybe the maintenance guy on a previous location took the air filter out and then didn't put one back in because he didn't have a part.
Sounds out there but it has happened. A buddy of mine took his infinity to a non-dealer. The guy said he needs a new air filter but he doesn't have the part. He gave me friend 2 choices, he could either wait a couple of days to get the filter, or go get a non-oem one from pepboys. My friend went to pepboys.
He didn't know how to put it in because he's never done it before on that car.
So i showed him. Before i opened up the airbox he told me that for some reason the car was running kind of slow and sluggish.
I opened up the box and there was no airfilter in there. He was like WTF??
What happened was the mechanic pulled it out and never put the old one back in.
What idiots.
What idiots.
Because Of You
Originally Posted by PACman
The pollen filter for our TSX is the same used on the US Accord. And it's way cheaper than $50. I bought some for about $16 each (genuine Honda part).
Wow!!! Really? Do you have the year and part#?
Originally Posted by CGTSX2004
You sure the fly wasn't already in the AC vent?
I saw the flies outside the car as I drove through them, and then the fly came shooting out the vent. It would be a big coincidence if it was in there all along.
There isn't a year for the filter.
Micron Air Filter (for the cabin)
Part# 80292-SDA-A01
Part# 80292-SDA-A01
http://cgi.ebay.com/ebaymotors/CABIN...spagenameZWDVW
Originally Posted by drigo
I guess I should just remove the filter in my S2000 since I never intend to replace it because leaving it in there is just going to impede my air flow. Or will removing it without replacing it not allow the system to properly seal up?
Received 3,860 Likes
Originally Posted by jlukja
So, fdl, have you verified that your TSX actually has the filter installed? Or that there isn't a hole in it. I mean, thats the only reason I can think of that the fly would come in through the vents.
She said: it's GINORMOUS!
i pulled the cabin air filter trying to trace a weather related creek; and the thing is pitch black!
it's only been 8k since i changed it - man nyc air sucks. i'm surprised humans are still alive. how do you LA people put up with the smog?!?!
Originally Posted by peter_bigblock
How often are you supposed to change the pollen filter? (Too lazy to get up and look in the owner's manual.)
er, um, I don't know how often. I think its something like every 30K mi.
now you can say you know how it feels to drive a motorcycle trhough a bunch of flies...
i wonder if it helps the smell of the car to change the filter? all that dirt and grime has to be a little stinky
ABP TSX
My filter at 28k miles. This is the original.
~fdl
Did you change the filter yourself? I noticed that the top & bottom of the filter fit in a small "edged" part of the filter tray. When I first positioned my replacement, the bottom edge fit snugly but not the top edge. The top was not in seated in the edged part. Hard to describe, but it left a 3-5mm gap in the filter area possibly explaining how a fly might have gotten into your interior.
~fdl
rcs86
08-02-2016 06:52 PM
