Did I damage my engine?
Move toward the window...
Last night, I stopped on a long open deserted stretch of road, and really wanted to open it up.
I switched my 5AT into sport-shift mode, and slammed down on the accelerator. I was under the impression that it would automatically shift once I reached redline. However, the RPM's actually reached halfway into the red zone (7500). I then felt a strong hesitation, almost as if the gas cut itself off.
I then eased off, and drove at slow, normal speeds. It seems to be running fine now.
First of all, is this normal? Is there a cutoff once the RPM's reach a certain level? And more importantly, is there a chance I could have f**ked up my engine or tranny?
This is the first and only time I've ever really drove the car really hard.
Any responses are greatly appreciated.
I'm think that you would actually have to use your sport shift (unlike some other hondas) to shift since it won't shift for you. And it's fine. Don't worry cause you just hit the revv limiter. No biggie.
I just got fuel cut off on 2nd gear this morning when I tried to pass a Convette still need more pratice on tsx to know when is the lastest shifting point after redline. And I already able to shift @7700rpm on my lude.
I had bad experience on a Pontiac Bonneville. When it cut off the fuel, it cut off the power of the car! steering lock up, no power brake and the car running on 100 miles/hr and I need to slide the car to the ditch in order to stop it! After that my family & I never never never buy a domestic! not even drive it!
Originally Posted by xizor
yes, no
OC: If you put the shifter in the SS gate, you have to shift it yourself. Otherwise leave it in D if you want the car to do it.
Originally Posted by dabuda
you have nothing to worry about...ive had my engine cut off from the same thing a few times already
so just out of curiosity, why would you think that the car would shift for you if you were in "sport shift" mode?
i really don't know, since i have a 6MT.
but your engine is ok, just hit the rev limiter which isn't the greatest thing to do, but youre engine will be ok.
just don't keep hitting it continously for a long time...
Originally Posted by Dan Martin
It's not a dumb question. If you didn't know what a fuel cut was you'd probably be freaked out too.
Thanks Dan... and it sucks to be such a noob.
Thanks everyone for the replies.
different "sport shifts" have different behaviors. my friend's "sport shift" 03 tiburon v6 forces a shift right before redline.
Originally Posted by dzuy
learn to drive stick then you
i intended this part of my post to the starter of the thread :
the sound of the revs is different from my ex-prelude vs tsx. thats how i usually know when to shift
did you civic even have vtec?
i hit the rev limiter with my 6MT, not the greatest feeling.
i've hit my rev limiter many times (10+ probably), but never on purpose. it started occuring after I got my CAI which drowns out the vtec sound at WOT. I hit it probably 4 times in one autocross lap I did, you'd be surprised how easy it is when you're accelerating around a turn in 1st gear and have more important things to think about.
Originally Posted by DEVO
I don't know why they can't create a soft cutoff... one that cuts power gradually instead of wham!
[QUOTE=dzuy]learn to drive stick then you
i really don't know, since i have a 6MT. [QUOTE]
some cars shift for you which defeats the whole purpose
Originally Posted by observer
Actually I think it makes sense that the SS doesn't upshift for you. There are situations where you want to hug the redline and not go to the next gear.
i luv it on mountain windy uphill roads its so fun. especially in an rsx. it handles good
btw: i do not own an automatic
BoricuaTL
04-08-2016 01:08 PM
Iakonafuji
09-21-2015 02:39 PM
Mugen TSX
Eastern Canada
09-01-2015 11:11 PM
