De-badge Instructions
hey,
i searched for "debadge" and "eblem removal" and couldn't find anything...
i'm planning on taking off the "acura" and "tsx" off the back of the car
i remember reading an old thread that just said you had to have a hair dryer and some dental floss....is this true?
i also read that i should use -emblem glue removal- instead of goo gone for the left over glue ???
anyone have any tips for me for this little project?
or if anyone has a link to an old thread for -step-by-step- instructions
thanks,
-j
thanks,
-j
this is what i did and it worked wonders
i parked the car in the sun for 20 mins
poured some hot water on the emblems
using the floss, removed the emblems
did not have any goo gone so i just used bug and tar remover
and rubbed any adhesive left behind off
Yeah, I suggest leaving your car outside in the sun before debadging. I used a blow dryer to heat up the adhesive then ran floss to remove the emblems. Goo Gone worked like a charm for me.
https://acurazine.com/forums/showthread.php?t=16883
Originally Posted by lcrazyaznl
You need to get 3m or that kind of 3m gluey substance.
if your neat you can just do plain 3m.
I see.. How do you know where to position the emblems back though?
Do you just have to estimate?
That's funny that TacoBellSauce put a transformer sticker in place of the A because I had been thinking the front grill of the TSX shares the same geometric theme as the the transformer's logo, sort of a cat or bird head rendered with straight edges.
Originally Posted by Toothman
All, about how long does it take to debadge?
Make a hole, coming thru!
Took me longer because I was very gentle with the Goo Gone (worked quick with the floss, leaving more adhesive on there), and also because I used some cleaner wax a couple of times, to remove any remaining stuff.
rcs86
Aug 2, 2016 06:52 PM
