De-badge Instructions
Old Jul 20, 2007 | 09:13 AM
Jay6speed's Avatar
hey,
i searched for "debadge" and "eblem removal" and couldn't find anything...
i'm planning on taking off the "acura" and "tsx" off the back of the car
i remember reading an old thread that just said you had to have a hair dryer and some dental floss....is this true?
i also read that i should use -emblem glue removal- instead of goo gone for the left over glue ???
anyone have any tips for me for this little project?
or if anyone has a link to an old thread for -step-by-step- instructions
thanks,
-j
Old Jul 20, 2007 | 09:29 AM
moda_way's Avatar
search by de-badge (like in your title) Tons of results
TacoBellSauce's Avatar
this is what i did and it worked wonders
i parked the car in the sun for 20 mins
poured some hot water on the emblems
using the floss, removed the emblems
did not have any goo gone so i just used bug and tar remover
and rubbed any adhesive left behind off
Old Jul 20, 2007 | 09:32 AM
Old Jul 20, 2007 | 09:33 AM
SHYUperman's Avatar
J M U ... DUUUKEESSSS
Yeah, I suggest leaving your car outside in the sun before debadging. I used a blow dryer to heat up the adhesive then ran floss to remove the emblems. Goo Gone worked like a charm for me.
https://acurazine.com/forums/showthread.php?t=16883
Old Jul 20, 2007 | 09:58 AM
taz98spin's Avatar
How do you reattach the emblems??
Old Jul 20, 2007 | 09:59 AM
Jay6speed's Avatar
Thank You !!!!!
Old Jul 20, 2007 | 10:17 AM
lcrazyaznl's Avatar
CL9 ABP
You need to get 3m or that kind of 3m gluey substance.
if your neat you can just do plain 3m.
Old Jul 20, 2007 | 10:22 AM
taz98spin's Avatar
I see.. How do you know where to position the emblems back though?
Do you just have to estimate?
Old Jul 20, 2007 | 12:10 PM
moda_way's Avatar
There are specific measurements from the Helms manual to position them.
Old Aug 11, 2007 | 07:03 PM
green_henry's Avatar
... or take some measurements of the existing emblem before you remove it.
Old Aug 11, 2007 | 07:11 PM
wackura's Avatar
That's funny that TacoBellSauce put a transformer sticker in place of the A because I had been thinking the front grill of the TSX shares the same geometric theme as the the transformer's logo, sort of a cat or bird head rendered with straight edges.
Old May 5, 2008 | 11:38 AM
Toothman's Avatar
All, about how long does it take to debadge?
Old May 5, 2008 | 12:13 PM
GTSX-05's Avatar
ASM 3G TL Type-S
All together I would estimate around an hour to an hour and a half, but time shouldn’t be a factor when undergoing such a modification or any modification, it should be about the quality of the end result, so don’t rush take your time. I will hopefully do a DIY, soon once I have my M3 trunk lip.
Old May 5, 2008 | 01:12 PM
davidspalding's Avatar
Make a hole, coming thru!
Took me longer because I was very gentle with the Goo Gone (worked quick with the floss, leaving more adhesive on there), and also because I used some cleaner wax a couple of times, to remove any remaining stuff.
rcs86
Aug 2, 2016 06:52 PM
gatrhumpy
19
Dec 31, 2015 04:22 PM
thegipper
Sep 28, 2015 01:01 PM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
08_UA7_Gr33k
Sep 27, 2015 12:42 PM
