Common Navigation Problems?
Old May 29, 2007 | 03:32 AM
I Was Justin You's Avatar
So my tsx will be coming off his warranty within the next few months and I am concerned about the navigation system having problems.
I have always been paranoid about the nav as the screen pretty much controls everything related to AC/radio so are there any common problems you guys have had with the nav system?
Old May 29, 2007 | 03:56 AM
blktsx23's Avatar
sometimes the nav will just act retarded.. like when i wanted to go somewhere.. it wouldn't list the street name.. and i was on unnamed roads.. and the nav would keep on recaculating it self.. also it seemed when i was traveling on the road.. it was like not showing on the nav.. and the directions were sooOOO off..
Old May 29, 2007 | 09:52 AM
mrgold35's Avatar
mrgold35
I've heard some folks having problems with the touch screen giving out in certain areas because of over use. I think it was because of pressing too hard over time in the same spot (like on the nag screen OK button). I try to use the voice commands, radio steering wheel controls, and/or joy stick to enter selections to give me a few extra years down the road.
You can also change the touch keyboard layout from alphabetical to QWERTY (typewriter style) to mix up the commonly used letters and not to wear out the touch screen also.
I’ve never heard of any other functions failing other than that.
Old May 29, 2007 | 03:39 PM
Stevestr's Avatar
Looking at the '15 TLX
I have 75K on my 2004 (2003) TSX and have no problems with the Navi other than an occasional lock up that usually resets itself with a turn on, off, on again of the car - much like Windows. The one thing I have noticed is that upgrading from my original 2004 (2003?) Navi disc seems to make the unit move a little slower.
The navi system does not control "everything" AC related, the only thing it controls is manual override of AC on and off and fan speed. You can turn the AC on via the "auto" button. The only other function you would lose with a bad navi is the ability to change the air position (floor, face, etc). You would, however, lose almost all audio functionality, though even most of those features have buttons on the face of the unit that control them.
Old May 29, 2007 | 03:59 PM
darth62's Avatar
Not an Ashtray
I stoped having lock-up problems like that after I upgraded the NAV disk.
Old May 29, 2007 | 10:00 PM
TommySalami's Avatar
E92
The nag screen needs to just turn into a disclaimer that pops up for a couple seconds while the nav boots up, or at least have an OK button that moves to a different spot each time
Old Jul 11, 2007 | 09:05 AM
06TSXeer's Avatar
My navi has been resetting quite often while I drive lately. Today it reset 4 times within an hour. Does anyone know what may cause this? I have a voltage stabilizer but I don't know if that affects it or not. None of the wires are loose in the navi unit.
Old Aug 17, 2007 | 02:11 PM
06TSXeer's Avatar
Any advice on this anyone?
Old Aug 17, 2007 | 07:21 PM
JDMPLUS's Avatar
mine does not have any problem.
take it to the dealership if your still under warranty.
I think you can find the tsx navi diagnosis step online. that way you can diagno.... yourself
Old Aug 17, 2007 | 08:00 PM
T-Mac's Avatar
The Mac
that just sounds like you need an update version of the navigation dvd. I would ask the dealer if they have any new versions with the update roads.
Old Aug 20, 2007 | 09:34 AM
mrgold35's Avatar
mrgold35
You might want to wait until about Oct/Nov for the latest DVD disk. I think Acura releases the updated disk once a year around this time for about $185+shipping/tax. I'm going to have to suck it up and get an updated disk this fall. I'm starting to have problems with finding addresses with my fall of 05 Navi disk.
Old Aug 20, 2007 | 09:54 AM
CGTSX07's Avatar
No problems so far with the Navi.
Old Aug 20, 2007 | 10:15 AM
JohnnyCatPSU's Avatar
3rd Gear
You can also push in on the joystick instead of hitting the OK button.
Old Aug 20, 2007 | 11:06 AM
bradykp's Avatar
Still Lovin my 06
i've had the navi for 30,000 miles, and the other day it reset randomly while calculating the route. it's the only time it happened. no other problems with it.
Old Aug 20, 2007 | 02:11 PM
tsx271811's Avatar
Sadly, the system itself is based on windows CE or something similar anyway. Hence the long startup time. Its def not as prone to freezing nor have i experienced it yet anyway on my 07' tsx.
Old Aug 20, 2007 | 03:17 PM
llJrockll's Avatar
Rebourne
mine is currently having problems. It keeps on restarting everytime I start the car. I'm going to the dealer to get it fixed/checked.
Old Aug 20, 2007 | 05:02 PM
E92
which is what I do, but it's still annoying
Old Aug 21, 2007 | 08:36 AM
06TSXeer's Avatar
The person that serviced my car said that the problem was from the navi control unit. They have ordered a new one for me and will call me as soon as its ready to be installed. If u guys find it happening more often maybe u should have it checked out.
Old Aug 28, 2007 | 10:55 PM
RogerPodacter's Avatar
So, do you like...stuff?
my navi worked perfect for 158K miles. now the dvd drive finally burnt out. out of warranty. the drive cost 4000 from acura. so i am doing it myself.
Old Aug 31, 2007 | 08:58 PM
idelgado782's Avatar
my navi was acting really bad when I first bought it. It always said, not on a digitized road, and was always going in circles. I took it to the dealer and they "checked it out" and said it was fine, I drove it home from work that night and it was worse then ever!!!! I think they adjusted the coordinates but the problem was deeper than that. I took it back the next day pissed off and I told the service manager to make sure they drove my car off of the lot before they called me back saying it was fixed. By the end of the day I received a phone call saying that they had to order me a whole new navi cause mines was dead!! Since it was fixed, I have not had any problems and my navi works perfectly.
Old Aug 31, 2007 | 09:04 PM
so i assume they fixed it for free? did they say what part exactly they had to replace? sounds like a weird problem too.
Old Sep 1, 2007 | 09:44 PM
Yeah that was under warranty. It was definately retarded, I stood without my car for like four days, and they gave me a loaner MDX, which I absolutely hated!!!!
Old Sep 1, 2007 | 10:35 PM
wow 4 days? why didnt they just order the part and call you when it arrived. then they could fix it same day and you wouldnt be without your car...
Old Oct 30, 2007 | 11:05 PM
HondaAcura83's Avatar
2008 Acura TSX
I didn't want to start a new thread about this issue.
On the brightness selection (Auto/Day/Night)... I pick Auto. Of course at night, it never changes. Anyone else experience this problem?
Old Oct 31, 2007 | 12:18 AM
andypenguin's Avatar
My brightness never changes either when set to Auto. I read somewhere that if the brightness were set at the "Default" value, whatever that's supposed to be, it will auto change. I've tried it set brighter, somewhere in the middle, dimmer -- it never auto changes.
Old Oct 31, 2007 | 12:37 AM
studville's Avatar
Doesn't Rice His Car
It's controlled by your headlights. Headlights on = night.
Also, You can't have the brightness of your gauages (speed/tachometer) set to the max brightness or else it won't work.
Old Oct 31, 2007 | 07:14 AM
Yup, studville is absolutely right. You can't have the gauges on all the way. Turn the knob to the left till you hear it make a beep but the brightness is still up, then when you turn on your lights it will change from day t night.
Old Nov 1, 2007 | 05:29 PM
smazzurco's Avatar
also, you might have the "day" and "night" set with the same colors. Go to setup and change it so they are different
Old Nov 1, 2007 | 07:04 PM
2008 Acura TSX
Yep. Thanks a lot studville. I guess I missed that in the manual
This rocks lol.
pstomps
Feb 20, 2017 03:29 AM
Sep 17, 2015 10:16 AM
vanderveen44
ILX
Sep 16, 2015 10:51 AM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
Gianni Formica
Sep 7, 2015 08:28 PM
