Car Myths
Car Myths
Well... not exactly "myths" but I just want to clear up some conceptual misunderstandings about how I should drive my car in terms of keeping it healthy.
1. Getting ready to start up your car for the first time, how long should you let it idle to "warm up"? my dad leaves it on for 1-2 minutes sometimes to let the oil get hot and so the engine can run more smoothly without sudden "bursts". I kinda don't agree on this; I feel that it's better to just let it idle for no more than 15 seconds then just drive the car slowly (under 2k rpm) to warm it up.
2. Common one. 3000 mile = oil change. Too early or just right?
3. What exactly CAN'T you do during your car's break-in period?(for new cars apparently) and ending period of break-in (how many miles?)
4. Any other Do's and Do not's with the TSX? or anything people think they shouldn't do, but actually can without harm and vice versa?
5. SS mode is bad for the tranny. when is it true and when is it not? duration matters?
Any other common misunderstandings you guys can add, please feel free to do so ^_^
ugh...sorry for double post but i left out a question
6. When I get my TSX, i don't want the license on the front bumper. Is this illegal or can it be done? (different from state to state I suppose?)... or better question, Does the front bumper come drilled? or does the license plate frame mounts on somewhere else?
stick with gunmetal, man!
change the oil every 3000 mi, you can tell how dirty it gets after 3000 mi, up to 4,000 is fine, but to be safe 3000 is the best bet since clean oil is the lifesource of your motor.
break in: don't push it too hard. don't change the oil for 4,500 mi, since it has a special formula in it.
ss mode is bad only if you red line miss-shifting doesn't really hurt it from my experience- i may be wrong. 80% damage to tranny happens at very high rpms.
you love your car. you show that in the way you drive,
if you drive fast you're sure to have an enjoyable ride- you'll love to drive
slow easy acceleration- you'll keep your car forever.
you decide
you decide
2. If you have a later model (06/07) TSX, follow the maintenance minder. Otherwise, just follow the manufacturers recommended maintenance schedule. There is no need for oil changes every 3000 miles unless you enjoy wasting money.
3. Don't red-line the car, don't drive at any one rpm for too long of a period, don't go full throttle. Break-in is only the first 600 miles (though some take it easy for the first 1000) so just keep your driving light for about 2 tanks of gas and you'll be fine.
4. If you have fogs, avoid leaving them on while the car is not in motion. They get pretty hot and need the moving air to cool them.
5. Nope. The SS mode is only a means of allowing you to control the transmission logic and it is designed to prevent you from being able to do something that can damage the transmission. There is no mechnical connection between your shift knob and the transmission so there is no way you can do any mechanical damage.
6. Check with your local state laws for whether or not it is legal. The plate frame is usually attached using 2 screws that are located in the lower grille area of the front bumper and are intentionally hidden so as to avoid the ugly holes if you choose to remove the plate frame.
I Quit
Originally Posted by LoveMyTSX
Another misunderstanding is that the TSX is fast. It's not fast but peppy.
1 BIG IMPORTANT THING about that front bumper (if you haven't already taken delivery of the car): I made sure to tell my salesman I would not take delivery if there were any holes drilled in the bumper. The car does NOT come this way, the dealer drills the holes to mount the license plate frame. There is 1 big, ugly hole front and center, that is all they drill. There are 2 mounting points underneath the frame that are also used, but are not visible unless you're under the car. Just make sure they understand you expect there to be no front plate holder installed.
Regarding the oil change question:
If you're using a full-synthetic blend(like Mobil 1 or Amsoil), even the maintenance reminder is way too cautios. You're safe to change oils at longer intervals like 5000-6000 miles.
Under normal driving conditions, Mobil 1's 5w30 has proven to maintain a high level of viscosity for distances of up to 26,000KM(15,600 miles!), but the recommended point of change would be at 10,000 miles.
I personally don't feel too great about keeping the same oil in my engine for 10,000 miles, so I change every 5000 miles.
Someone stole "My Garage"
Almost all of your questions are going to be answered with pure opinion or personal preference, so take them all with a grain of salt, and maybe do some reading via a search.
Personally (there's the hidden word for "opinion"), I don't let the car warm up during the warmer months, and during the winter, it warms up as long as it takes for me to brush the snow or scrape the windshield.
As for oil change intervals, I'm running in-between the severe and normal schedules. 12,000km OCI on a full synthetic, heavy duty 0w-30 oil. 3000miles/5000km is an utter waste of money.
I like to run my cars hard on break-in, but a "controlled" hard. gradually work up to redline over a few moderate to high throttle runs in 2nd or 3rd gear. Then dump the oil within the first 500 miles and run it smoothly, varying the rpm's, until your first scheduled oil change.
Only #6 has a solid answer: If you're a law-abiding citizen, keep the plate there. If not, then remove it at will and don't complain when you get a ticket.
Let me help you!
[/QUOTE]
Let me help you!
You can also relocate your license plate. I moved mine down, since the license plate bracket tends to hit the bumper and wear out the paint...
