Bizarre AC issue!
Old Jun 27, 2020 | 09:16 AM
farristrey's Avatar
8th Gear
Bizarre AC issue!
So I went through the AC system on my 2004 TSX yesterday. Took 11 hours to remove EVERYTHING, flush, replace desiccant filter (clogged up bad!), replaced compressor, expansion valve, and every oring in the system. When i drew a vacuum it held perfectly. Didn’t loose anything in 2 hours after shutting vacuum pump off. I then charged with 19oz of freon. Car blow ICE COLD, but only on fan levels 1-3. If I hit fan level 4, or 5 (max), it kicks the compressor off after about 1-2 seconds. So I ran the ac diagnostic and get no codes. I’m at a loss as to why when increasing the fan level above 3 the compressor cycles! It will stay on 3 and stay engaged no problem. Can I get some input from the community? Thank you. BTW my high side reading was perfect, low side was at 35, should have been a bit higher but don’t see the relation with the fan speed.
Old May 22, 2023 | 12:46 AM
GeorgeTSX's Avatar
2004 TSX NAV 5AT MSM
Did you ever resolve this? Was it any of the sensors? I have to take my car in to get the A/C fixed (I have to get the compressor and condenser replaced at the very least).
nollid
Aug 6, 2019 03:28 PM
97'CL2.2
1G CL Problems & Fixes
Oct 9, 2012 05:59 PM
rfsurfer
1G TSX Problems & Fixes
Feb 24, 2011 05:20 PM
utkelvin
Sep 11, 2008 03:25 PM
FISHYTL
Aug 4, 2006 10:43 PM
