AC- only works when on the highway
Old Jul 14, 2019 | 12:45 PM
nollid's Avatar
99 Acura TL
Hello gang, long time no post. 99 TL. My AC suddenly started acting funky. I can turn on the car and wait twenty minutes, and the AC will still be blowing warm air. It is not until I get onto the highway that it gets cold. Any ideas? Not sure if it is related, but I have also started to notice recently when I turn the car off the fans are still running.
Thanks!
Old Jul 14, 2019 | 01:05 PM
01acls's Avatar
Replace the radiator.
Old Jul 15, 2019 | 08:18 AM
nollid's Avatar
99 Acura TL
Thanks for the reply. What is a fair price to have that done in a city?
Old Jul 15, 2019 | 08:59 AM
01acls's Avatar
If you haven't add freon to the AC system in recent years then you should have the shop check for a low ac charge first before doing anything else. Also check the AC condenser and radiator for debris/blockage, no air flow, no ac.
2.5 hours of labor plus parts and coolant cost is about right for the rad. However, I miss read your original post. I thought the fans was not coming on when the car is running, since the fans are working with the car on and off then probably no need to replace the rad.
Old Jul 15, 2019 | 11:40 AM
nollid's Avatar
99 Acura TL
Thanks again for the info! I had it charged up last summer :-\
Old Jul 15, 2019 | 12:38 PM
01acls's Avatar
Then check for debris in the condenser.
Question, when you turn on the ac to Max cold with the Recirculating air on- button indicator light is on, what are the radiator fans doing with the car motor running at idle?
1. Off all the time?
2. On/off cycling variable fan speeds?
3. On/off cycling low fan speed?
4. On/off cycling high fan speed (very windy)?
Old Jul 17, 2019 | 06:54 PM
nollid's Avatar
99 Acura TL
This is what I observed today
- turn car on (ac off)= fans off
- turn ac on = left fan on
- toggle speeds= left fan on
what is old is that it is a very hot humid day here today (91, NJ), and I noticed cold air blowing almost immediately. So I am unsure if what I observed matters bc the problem may not have existed. I was unable to take the car out for a ride tonight to check to see if hot air would start coming out.
Old Jul 19, 2019 | 07:44 PM
Karanx7's Avatar
Unregistered Member
You're saying the driver's side fan turns on, but the passenger side doesn't? Sounds like you have a broken fan then.
Old Jul 21, 2019 | 02:43 PM
nollid's Avatar
99 Acura TL
Correct. Are both always suppose to be on at the same time?
Old Jul 22, 2019 | 01:22 AM
01acls's Avatar
You need to know if the right side fan is working or not. Hence my question in Post #6. Let me try a different way.
Q: AC ON MAX COLD (AUTO MODE) WITH RECIRCULATING AIR ALSO ON, ARE BOTH AC FANS ON HIGH?
Old Jul 22, 2019 | 11:39 AM
nollid's Avatar
99 Acura TL
Negative, nothing got the passenger side fan to kick on.
Old Jul 22, 2019 | 01:56 PM
01acls's Avatar
Fan not working a good sign for you, probably why ac is not cold at idle.
Swap the working fan relay with the non working fan relay and see if problem follows?
Old Jul 24, 2019 | 10:53 AM
nollid's Avatar
99 Acura TL
I played with the passenger side fan by manually spinning it, and occasionally the fan would spin on its own slowly then die out. I believe the motor is getting power, but it fan motor is toast. Do you agree? I did not get a chance to swap relays, only swapped power harnesses and did not see a difference.
Old Jul 24, 2019 | 12:56 PM
01acls's Avatar
If you mean swapping harnesses as in swapping the fan power plugs, then that would be the same as swapping relays. In this scenario then that is the correct diagnose, a defective fan, because in the original plug position the fan was working at full speed.
BTW, the climate control has a self diagnosis program feature. I think you should give that a try, it's worth a shot... Do search. If there is a fault it will store the code.
Old Jul 24, 2019 | 03:53 PM
nollid's Avatar
99 Acura TL
Thanks! I just saw a thread on that self diagnosis program last night, I was blown away- did not know that existed! I am planning on trying it out before I install the fan tommorow.
Old Jul 24, 2019 | 07:10 PM
nollid's Avatar
99 Acura TL
Diagnostic codes came back as:
I- Air mix control motor - open circuit
K- Air mix control motor - obstructed door, faulty motor
Old Aug 6, 2019 | 03:28 PM
nollid's Avatar
99 Acura TL
Replaced the fan, and it is working now.
Diagnostic test still returns the same code, but oh well?
H-Town-TL
Mar 4, 2017 01:14 AM
ComptechTSX
1G TSX Problems & Fixes
Aug 29, 2014 01:26 PM
CPR
Jun 30, 2008 07:17 AM
Lucky37
Feb 20, 2005 08:53 PM
