backseat problem
backseat problem
has anyone had there middle backseat pop out when extended? when mine is down, and i bump it from either side, it pops out of joint and rips the leather where the pegs are. i took it into the dealer and they replaced the folded parts and components, and i tested it with a light slap, and the damn thing came out again. can anyone else tel me if they have this problem? i think its just real sh*tty designing, cuz no other car that i have checked for it has the same problem
Re: backseat problem
the test is to fold it down, and give it a firm push from each side, right at the end of the armrest (furthest from back).
if anyone gets time to test it, plz reply
I have no idea what you're talking about, dude. Are you talking about the rear seats when they're folded down to access the trunk?
What is the problem you're observing? The armrest in the 60/40 split comes off? What do you mean by "slapping" it?
ill make it clear then. sitting in the seat behind the driver, with the seat up, (not to access the trunk). fold down the seat beside you (the arm rest with cup holders), that is the thing that comes out all the time. if someone is sitting with the armrest down and i turn too hard, it pops out of its holders. i noticed it first when i was driving some friends around and one of them said it had came out. so the next day i went out and checked what happened and realized that its just really weakly put in. so i pushed it into the slots and gave it a light shake side to side. and it softly came out, but i noticed that is has pegs that fit into a hole(the joint that keeps it in, and allows the up and down movement). i noticed taht those pegs were pulling on the leather around it and ripping it, so it has become a concern.
i am taking my car back in to the dealership again to get some stuff down and i would appreciate some input from other TSX owners that would help me explain whether it is a design issue in general, or my TSX problem.
Hmmm. So your rear seat armrest is loose? The whole armrest (cupholders and all) dislodges from the seatback?
I would definitely take it to the dealer and have them take a look. Even if it's a design defect, it should be repaired. If it keeps breaking, then keep taking it in... I guess.
all i want is for someone to go out and try it when they go to the store or something and give me a aye or nay. as in it happens or not
but yes, i took it in, got new peices installed but its the same as before with a shinier armrest.
can anyone tell me if their armrest is weak supported at the hinges?
all i want is for someone to go out and try it... and give me a aye or nay. as in it happens or not
wow... someone just delete this post i started please. i put up my problem to see any common problems, but all i get are unhelpful answers.
i didnt tell anyone to force it. i said just push slightly. why dont you just have someone sit in the backseat without a seatbelt, and you just turn at ridiculous speeds. it would help me if you did.
my family owns a shit load of vehicles, i tested every car with the same test. no damage, infact i dont think i could get any of them to budge unless i started throwing my weight into it.
but if doing this little test pops it out, then its helping my cause, because im taking it to the dealerships attention about a poorly built part of the acrura tsx.
so please, admins either get rid of this post, or someone give me some real feedback. but if your worried about breaking your car, dont reply
Take it easy, it's OK.
I think the main problem was that your first post was very unclear (and misleadingly worded) about what the problem was. Most people probably had no idea what you were talking about, and the few people who thought they did know what you were talking about were basically wrong -- all because it was so unclear. And, I think you can understand, that can be annoying. Not their fault -- and not yours either.
It happens.
It happens.
thats a fine response larch, thanks
and my friend must have fooled around and broke it then. so ill take that in, it must be that everyone else's is in rock solid and mine was just broken real easy.
My Accord seat had the same issue, when I installed it wrong many a time.
Never ripped the fabric
Any how, lift up on the fabric at the back of the seat (OE velcro) and you should see some bolts. Try removing and reinstalling the panel, it may take a try or two but eventually it should stick and mount in the factory pivot points. Sometimes I leave the bolts out and close the seat back several times until is clicks into the slot, then I install the bolts.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
