Added some LED drl's
Old Apr 4, 2011 | 09:58 AM
TuffguyF4i's Avatar
Not bad for $60! Super bright and have lasted a month so far. Matches HID color very well.
4 ft back
15 ft back
Old Apr 4, 2011 | 09:59 PM
huludicidal's Avatar
Almost Doctor
Do you have daytime photos of where/how these were mounted?
Old Apr 5, 2011 | 07:36 AM
aCUREa's Avatar
good job on the install
you should post some day shots since they're DRLs
Old Apr 5, 2011 | 11:32 AM
TuffguyF4i's Avatar
NP...day shots will come. Life always gets in the way of my projects!
Old Apr 7, 2011 | 12:25 PM
Fox137's Avatar
Also, where'd you get the kit?
Old Apr 7, 2011 | 12:31 PM
wes.sinclair's Avatar
6th Gear
How diffuclt was this for you? I'm new to cars and would love HID or LED DRL..
Anyone notice any problems with their battery after adding either vs. stock DRL?
Old Apr 7, 2011 | 01:41 PM
TuffguyF4i's Avatar
Got the kit here.. http://www.dealextreme.com/p/univers...car-pair-45608
It is a chinese company. They might take up to 40 days to get to you but that is just to be expect from them. Mine took about 30. Good price though and they come with a driver, which is absolutely critical for long life.
I have had mine on for about 30 hrs with no issues.
No, LEDs are VERY good on battery life.
There are only 3 wire to hook up.
1 for ground (i used main battery ground)
1 for hot + (i used running light hot)
1 for cutoff. I did not hook this up, but the idea is that you turn on your low beams and the leds turn off. Frankly, i like them on so i didn't do it.
The only tricky part was the mounting bracket. The screws that go into the housing that hold the light at the right angle, SUCK. I drilled them out and put in larger threads and bolts and that worked well.
Old Apr 7, 2011 | 01:42 PM
KillerG's Avatar
Op is too busy to care
i came to see what monstrosity had been unleashed, but they actually look pretty awesome. more pics please.
Old Apr 7, 2011 | 02:24 PM
6th Gear
(this might be a really stupid question but WHY am I not seeing pics here and on other treads?!) thanks...
Old Apr 7, 2011 | 02:36 PM
KillerG's Avatar
do you see this pic? re-hosted in case photobucket is blocked for you
Old Apr 8, 2011 | 11:53 AM
Almost Doctor
F4i, we ever getting daytime pics?
Old Apr 10, 2011 | 08:07 PM
Thermos's Avatar
I did something similar last summer, then got pulled over by a cop saying it was illegal so I had to get rid of them. Now I've got the JDM yellow fogs which I will soon convert to HIDs..
Old Apr 10, 2011 | 08:10 PM
KillerG's Avatar
^ therm, blue is definitely illegal, but you mighta gotten away with it if they were white
Old Apr 10, 2011 | 09:46 PM
Thermos's Avatar
To be honest I read the "Highway Traffic Safety Act" for Canada and it seemed to mention that "flashing blue and red lights" are not allowed. I figured plain blue LEDs that are not flashing would be alright, but I was wrong. Was fun while it lasted though.
P.S I've seen trucks on the road with blue LED strips on the front. I wonder if they get pulled over..
Old Apr 10, 2011 | 10:20 PM
GWEEDOspeedo's Avatar
El Cunado
These seem cool but they shine so high. Can you aim them at all?
Old Apr 13, 2011 | 02:18 PM
TuffguyF4i's Avatar
Nope...drls go all over the place. I think even the stock halogens are a flood light.
drls are just for other driver visibility. Getting seen, not illuminating the road.
Old Apr 13, 2011 | 02:46 PM
aCUREa's Avatar
The stock halogens are not flood lights... they're high beams... way different in that flood lights aren't aimed like high beams are. They are optically suited for a high beam application. This is also why they're not the best choice for DRL, but they'll suffice.
Optically speaking, the turn signals would be the best in terms of scattering light all over for DRL, but the only problem there is the plastic sockets will burn eventually.
Old Apr 13, 2011 | 07:18 PM
Almost Doctor
The OP is a no-show. I mean how hard is it to post a few daytime pics.
Old May 2, 2011 | 01:26 PM
SexyNavytsx's Avatar
man those look hot, op do you have fogs on your lower grill to. i was wondering if the connections can just connect into the lower fogs?
those look the the audi a6 ones just smaller.
RLX-Sport Hybrid
3G RLX (2013+)
27
Dec 7, 2018 12:11 PM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
Ratheruneeq
Sep 28, 2015 07:41 AM
greeneyes.hypnotize
Sep 27, 2015 02:47 PM
eastcoastguy
Sep 23, 2015 06:29 AM
