Acura 45-point check
'04 CG TSX
Hey -
Did any of you get this mail from you're acura dealer about acura appreciationw week and a free 45 point check. I got it from my dealer.
Have any idea what do they check when they mean 45 point check. I am nearing my 10,000 mile maintenance and was wondering if I should use 45 point check to verify the brakes, wheel alingment etc. and if everything is fine, just get oil change as part of 10,000 mile service .
let me know you're suggestions.
Thanks for you're time.
A 45 point check probably just includes peaking under the hood to make sure the hoses and clamps are properly attached, fluids are topped off, then checking your brake pads, tire pressures, tire tread depth, and anything they can do pretty much visually.
Might be good if you just need someone to do a quick one-over on the car.
I didn't receive anything and even if I did, I think I'd laugh if they offered it to me. I can do a 45 point check myself and it would bring me to the same conclusion after 31k miles, everything is fine.
Originally Posted by Dan Martin
Does it have an Engine? Check.
Does it have four wheels? Check.
How about four tires? Check.
I'm up to three already....
Originally Posted by manavi
That's just a marketing ploy to get you into the dealership so you can buy something. Either another Acura or service/accessories for your current Acura.
The point of the inspection is to get you in there, and if they find something wrong with it, then they'll get you to pay for something.
It's mostly visual though. Checking for leaks, fluids, etc...
Sort of like why they offer free "alignment checks".
They're probably certain that most people that get the "Check" will need one. That's why they can offer those free all day long.
Its Free And The Inspection Meets The Scheduled 10,000 Mile Service Check, Add An Oil Change And A Tire Rotation And You Have Yourself A Dealer Performed/ Factory Recommended Service.
I Think It Would Be Worth Going. Have Them Stamp Your Book!
BobbyGraham388
10-22-2015 05:05 PM
braveheart
09-07-2015 08:12 AM
