For the 6 speed owners, did you notice that the 1-2 shift isn't geared well?
i noticed that 1st ends around 38 mph, and when i do some spirited driving i take it to the red and drop it quickly and let the tires chirp, and gun it again but i get this noticeable lull right before it has to go back up to 5000-5500 rpm, and when its time for the 2-3 shift, it gets right into its powerband with no lag whatsoever since the 2-3 gear ratio is just a bit tighter..... and the time lost in the soft spot can't be recovered in a straight line race even though thats the last thing the TSX should be doing....
I think we termed this the 1-2 thud/dump a long time ago. Though not good for the clutch, as you go from 1-2, slip in 2nd if at high revs or short the top rev by 500 RPMs and the thud is more manageable I have found out. This was a common thing for 04-05 TSXs, but I think it was managed better/disappeared in the 2006.
08 MDX with Sports
Uhh where have you been? Its been like that with all of Hondas/Acuras for the last 6yrs..
I heard getting short-shifter or installing clubrsx metal bushing helps..
Nope, my 06 often has a problem with the 1-2 shift, and it's there at different engine speeds. It seems more a function of electronics (DBW?) than gearing, when there is a definite cut-out of power, at high rpm, even though my foot is on the gas.
The low-speed shift isn't nearly as annoying as my wife's wtf-are-you-doing look.
Is your VSA off? If you chirp with it on, it will apply the brakes to "stabilize" the car. No matter what though, there's always going to be a power dip at 5k. Unless you get Hondata
for EVER more!
I've noticed this for sure. Maybe it's the tech overcompensating?
Also, I skip 3rd gear very regularly on a fast acceleration from start to 70 mph. I'll go 1-2-4-6 on my way up. Anyone else do this?
Have camera, will travel
Discussed many, many times before, and moda_way, I think the '06 MT is exactly the same as previous models.
Black 6 speed rectified the problem by changing out certain gears, but I can't remember exactly what he did...installed RSX gearing? Something like that.
Someone stole "My Garage"
It wouldn't shock me that your 4th gear synchro is getting worn a lot faster than the others.
From the way the original poster described it, the "lull" during the upshift sounds like the DBW cutting throttle. If this is the case, I hate this as well.
Although my avatar says otherwise, I don't turn VSA off all the time. I'm thinking of getting the KPT mod for this. VSA was responsible for some close-calls where my aggressive decision needed some hard accelerating. At times, the darned thing would cut the throttle and traffic would almost hit me.
Unfortunately, not even my RSX-S gears compensate for this stupid thing. It might actually make this thing worse when VSA is on because I land higher on the RPM band (usually vtec ) There isn't a single day I've driven my TSX where DBW would actually benefit me outside of saving my tires and possibly clutch wear. I'll take a cable-throttle anyday.
Optimal gearing has been sacrificed for 0-60 times, and 2nd is geared too tall (overall for the transmission) so that you can hit 60 mph without requiring another shift.
The 1-2 gap is disproportionately large compared to the other gear spacing.
such a dirty birdy
I always figured the 1-2 gap was not to optimize 0-60 times, but to compensate for the (perceived) lack of low-end torque. That is, the car feels quicker off the line because of the low gearing of 1st. It's always felt to me like the 2-3-4 ratios were spaced about right, and that 1 was just too short.
Oh, and to complete vwong's 2003 flashback, how about I complain that the 5-6 gap is too small.
This space taken.
I noticed this for the first time yesterday actually. I didn't notice if the VSA light came on - I didn't see it (but was being thrown forward), but it felt like a cut. Very odd though, because I had never noticed it until yesterday (only had the car 2 weeks) - I don't drive it hard except on rare moments.
Is the consensus that this IS caused by the VSA cutting the throttle, or is it just a severe lug?
Interestingly enough, I did once take the car just shy of the rev limiter, and except for the VSA system kicking in momentarily to quelch wheelspin, I didn't feel as severe of a lug.
