2007 TSX PS fluid replacement
Old Mar 8, 2012 | 05:40 PM
Artbuc's Avatar
Getting ready to do niece's car. Has 78k miles and PS fluid is nasty dark brown.. I have only done PS fluid replacements on Toyota and Lexus.
I like to replace PS fluid without starting the engine. I disconnect return line from rack and divert it to waste container, plug return port on sump and slowly turn wheels lock to lock while keeping sump topped-up with fresh fluid.
I notice that the TSX PS pump is higher than the sump. Will my usual method work with this arrangement? When I disconnect the return line to drain the sump, won't the fluid drain out of the pump suction line causing slugs of air to enter the system? What keeps the fluid in the pump suction line from draining back into the sump when the car is turned off? Check valve?
I don't want to use the turkey blaster method because I want to replace all of the fluid as efficiently as possibe. Thanks.
Old Mar 9, 2012 | 03:49 PM
Artbuc's Avatar
Got it. Should have done some Googling before I posted.
mada51589
Jan 9, 2025 04:40 PM
cobra10363
Jul 23, 2024 04:13 PM
cycdaniel
Dec 17, 2019 10:58 AM
nanos
Nov 12, 2015 08:41 PM
Marmbo
4G TL Problems & Fixes
Sep 21, 2015 09:39 AM
