06 Ipod Aux help!
Old Jan 5, 2006 | 10:20 PM
goOkOnE's Avatar
8th Gear
06 Ipod Aux help!
Went to pick up the wires for my Ipod to plug into the built-in AUX in the 06 TSX, but when I got home to open it, it's not the right one. Can someone link me the wire that will fit and work?
Thx
Old Jan 5, 2006 | 10:21 PM
GIBSON6594's Avatar
My Garage
I'ts just a headphone jack right? what kind of wire did you buy?
Old Jan 5, 2006 | 10:39 PM
KunalPatel87's Avatar
TEMPLE OWLS Don't Sleep
http://store.apple.com/1-800-MY-APPL....8.25.7.11.0.3
Thatz what you need!
Glad to help
Let me know how the quility is when you buy that.
Old Jan 5, 2006 | 10:45 PM
goOkOnE's Avatar
8th Gear
I bought this..
http://catalog.belkin.com/IWCatProdu...duct_Id=178147
Old Jan 5, 2006 | 11:06 PM
goOkOnE's Avatar
8th Gear
Ok. So I messed around with it some more and got it to connect and play, but I still need a different wire, the belkin one does not seem to want to plug into the car's aux and hold tight. I have to hold it in place. Bleh!
Thanks for help
Old Jan 6, 2006 | 10:21 AM
Runt888's Avatar
http://www.radioshack.com/product/in...ductId=2102970
Old Jan 6, 2006 | 10:53 AM
camman's Avatar
8th Gear
Apple Aux Cable
Glad to help
I use this cable and it works fine albeit it's quite long!
Old Jan 6, 2006 | 11:46 AM
skipreid's Avatar
http://www.trianglecables.com/2footminster.html
I bought this one. Perfect length and it matches my ebony interior.
Old Jan 6, 2006 | 01:18 PM
Tmetcalf's Avatar
$4.29 for a 6ft. long stereo cable from Radio Shack. They also had the 1ft cable but I decided it wasn't long enough. Now I can have people in the back of my TSX play with the Ipod without having to stretch across to the front of the car!
Old Jan 6, 2006 | 01:31 PM
goOkOnE's Avatar
8th Gear
Can you guys control your IPOD from your stock head unit? I can't adjust volume or search tracks from the dash. Only from IPOD.
Old Jan 6, 2006 | 01:44 PM
cusetsx's Avatar
05 ABP NONAV BONE STOCK
Just connecting to the AUX port will not give you control of track changes. It effectively is like connecting a headphone to your iPod... instead you are routing it to the AUX input of your Stereo. You should however have the ability to adjust the volume of your stereo with the steering wheel control or head unit knob regardless of you using the AUX input. Do make sure your iPod volume isn't cranked though as this might make it appear that you can't lower your volume enough to make a difference.... though bringing it to 0 SHOULD make it mute regardless of the volume of your iPod.
Correct me if I'm wrong here folks...
If you wanted control of your iPod you have to buy the other accessory ($$$) to connect to the dock connector of the iPod.... unless you have that and haven't mentioned it.
Old Jan 6, 2006 | 01:54 PM
goOkOnE's Avatar
8th Gear
Thanks a ton for the info. Much <3
Old Jan 13, 2006 | 12:01 PM
notjoeyt's Avatar
3rd Gear
Monster Ultra Low Profile Charger
Hi guys, I am new here (new car in next 6 months, usual suspects), but I have a iPod interface in my wife's Mazda Protege5 (custom interface just for Mazda's). I originally had a headphone cable from the iPod's headphone jack to the car's radio, but the sound was questionable (good but not great).
I got the Monster Ultra-Low Profile Charger for iPod with Dock Connection over the holidays, what a difference. The Monster connection uses the dock connection on the bottom which puts out much better sound (it does not use the internal iPod amp, which can distort music). This way, you get true line-out sound quality. I highly recommend it. I think it is $80 her is Canada but only $35 in the states.
This is similar to the Belkin auto kit, but the Belkin adds its own amp back into the process. You may get line noise and distortion with the Belkin unit.
Old Jan 13, 2006 | 02:18 PM
belfer's Avatar
TSX iPod
How is the sound quality for the iPod in the TSX? I'm getting a TSX this spring, but I have an adapter in my RSX now. It really minimizes the volume going through the adapter even when I mess around with my iPod's settings. I was excited about the direct auxillary jack in the TSX figuring that the sound quality would be maintained. Is this the case?
Old Jan 13, 2006 | 02:24 PM
dj Dozhe's Avatar
6MT or Death
In comparison with everything else the aux is great quality. Connecting from a base unit like the belkin or monster is a little better to the audiophile ear. Mine being one of those, but the aux is still badass.
Old Jan 13, 2006 | 04:07 PM
bradykp's Avatar
Still Lovin my 06
Repost
https://acurazine.com/forums/showthread.php?t=27615
Search feature works miracles for noobs
Old Jan 14, 2006 | 01:27 AM
MikeMa's Avatar
No Longer a Poseur
Any connector that gives you audio from the dock connector is going to be better, since the dock connector gives you Line level out....the port on the top is headphone level out.
Old Jan 16, 2006 | 11:28 AM
Tmetcalf's Avatar
In my old 99 Accord I had Griffin Itrip to connect my Ipod to the stereo, but I could never find a great connection that wasn't interupted by a radio station. But that may be due to me living in the greater LA area where there are thousands of radio stations. The quality on the new AUX hookup in the TSX is great, and the sound quality is as good as the CD quality. Not having to tune the Itrip into a radio station makes such a difference. That was one of the biggest selling points on the '06 TSX. I just wish Acura could of stretched there budget a little further to include the cable !!
4drviper
Apr 23, 2025 07:13 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
ValdezQ26
Oct 1, 2015 04:48 PM
TLguy42
Sep 26, 2015 11:27 AM
