terrible whine.
Old Apr 23, 2011 | 07:21 PM
7 Tl's Avatar
terrible whine.
Fellow first geners, I have a noticeable whine coming from somewhere around the engine I couldn't pinpoint exactly from where because it whines when im accelerating between 0-20 . Have any of you had something like this & can help me out with a probable cause ?
Thanks....
Old Apr 23, 2011 | 11:29 PM
Go90go's Avatar
大日本帝国
Check your belts.
~Cheers~
Old Apr 24, 2011 | 12:57 AM
7 Tl's Avatar
what would be safe to use when lubing belts if that were the case?
Old Apr 24, 2011 | 01:59 AM
7 Tl's Avatar
i couldnt wait & checked again. I narrowed it down to the alternator. It seems to have some kind of chirp when spinning.
can't drive it like this , its embarrasing
Old Apr 24, 2011 | 02:20 AM
9632tl's Avatar
Radical Member
Bar soap. Don't use belt dressing, it melts the belt.
Old Apr 24, 2011 | 02:23 AM
7 Tl's Avatar
^ I actually heard that one but never took it seriously.. Tell me how to do that im gonna go ahead & try it.
Old Apr 24, 2011 | 10:53 AM
96TL_X's Avatar
It happened to mine once before. I dont know if its the same noise as yours but mine was because of loose timing belts.
Old Apr 24, 2011 | 11:51 AM
7 Tl's Avatar
mine is kinda like a chirp as one of the belts runs
Old May 1, 2011 | 05:10 PM
RockAboutBaby's Avatar
Normally those noises are most of the time associated with belts. If your belts arent loose, check the pulleys, rusty old pulleys will do that noise.
I'm interested in a quick fix as well, mine do it but only for a couple seconds on cold start up.
How do you use that soap bar?
Old May 2, 2011 | 01:19 AM
Go90go's Avatar
大日本帝国
If it's chirping, it's the pulley. Hit the bearing with some silicone lube and see if it goes away.
~Cheers~
Old May 2, 2011 | 02:12 AM
~Cheers~
Would lithium based or multi-purpose lube be just as good if not better? I just emptied up my silicone lube doing all the rubbers and wires on the car.
Old May 2, 2011 | 02:59 AM
Go90go's Avatar
大日本帝国
White lithium should be fine, it's just that I've found that silicone lube is a bit better if you don't have everything taken apart.
~Cheers~
Old May 3, 2011 | 12:29 PM
Will do as soon as it stops raining outside, I take it that you only spray the pulley bearing without hitting the belt (at all if possible) right?
Old May 3, 2011 | 01:37 PM
Go90go's Avatar
大日本帝国
You can hit the belt, it shouldn't do anything.
~Cheers~
Old May 9, 2011 | 11:29 AM
rlarge98tl's Avatar
Just started having the same issue but only does it when I start the car but seems to quiet down as I drive then stops. Hope its not the timing belts, sounds expensive
2ManyHobbies
Sep 24, 2015 09:23 PM
carz0159
Sep 20, 2015 06:11 PM
Skirmich
Sep 15, 2015 06:41 PM
gqdabien
Sep 8, 2015 11:41 PM
iRaw
ILX
Sep 5, 2015 12:10 AM
