Parking lights not working
Old Mar 16, 2010 | 08:19 PM
NFAMOUZ's Avatar
Audio Apprentice
When I turn my lights on, my side marker lights, fog lights, and back lights do not come on (headlights, braking and reverse are fine), also my guage cluster and heating controls remain dark. I installed a new head unit last friday and this problem didn't occur until last night when I turned my car on to go to work. I'm assuming all of this could be happening because of a blown fuse? I have no idea, any help is greatly appreciated.
Old Mar 16, 2010 | 08:27 PM
simm's Avatar
98 Blue 2.5 TL 200,050 mi
Fuse.
Old Mar 16, 2010 | 08:31 PM
NFAMOUZ's Avatar
Audio Apprentice
woot thanks, do you know what fuse I need to replace and where it may be located? It's a 97 TL 2.5 if there's any difference between it and the 3.2
Old Mar 17, 2010 | 05:33 AM
simm's Avatar
Your manual should tell you..
Old Mar 17, 2010 | 01:01 PM
NFAMOUZ's Avatar
Audio Apprentice
I checked the manual and replaced a fuse, but still no luck :-/ so I called a local audio shop and there going to take a look at my new head unit to see if it's the cause of the problem
Old Mar 20, 2010 | 12:59 PM
NFAMOUZ's Avatar
Audio Apprentice
ok, well I couldnt wait for my appointment at the audio shop, so I just went to a local Honda dealership, they told me that the head unit needed to be rewired and fuse replaced, I did that and problem solved
Old Mar 20, 2010 | 03:51 PM
Go90go's Avatar
大日本帝国
Glad that everything is solved. Was the power for the HU crosswired? Or was it shorting to chassis?
~Cheers~
Old Mar 21, 2010 | 06:35 AM
NFAMOUZ's Avatar
Audio Apprentice
to be honest I have no idea, but on the adapter there were a couple of extra wires that I didn't need and I didn't wrap them up before putting the H/U back in, so I think them being exposed had something to do with it
Old Mar 27, 2010 | 07:30 AM
DiabloSVRacer's Avatar
i think i know what it is. i had the same thing happen. its a wire(don't know what it is called i forgot) is grounding out and blowing the new fuse. the wire that was grounding out for me was behind my radio, i installed a new double din and left that wire hanging and it kept grounding out and blowing the fuse. my taillights were not coming on and my guage cluster had no lights. so check what you recently fixed or installed on ur car and see any loose wires
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
acurajj
Sep 19, 2015 03:47 PM
theinsvnity
Sep 10, 2015 10:22 PM
