okay radiator hose broke
Old Jun 11, 2011 | 06:21 PM
KrayzieDxC's Avatar
Khmer Pride
i toke a drive to mass. this wednesday ..and i came back the same day, half way home my car was smokeing so i pull over at 711 to check it out.. pop the hood and there you go a mad smoke came out..check it out the radiator hose split..i cant drive home so called for tow truck ,23 mile to get home.
i got it home.. started removing everything out to replace what is needed to be replace.
i have replace the hose and the coolant with the type 2 blue.
but after the fix i forgot the thermostat.
now my temp is going up and down..what else i need to do.
thermostat is not oem..which i might have to go buy the orginal one.
when i drive i put on the heater the temp rasie a little and then when i turn it off it goes back normal.
Old Jun 11, 2011 | 06:58 PM
Go90go's Avatar
大日本帝国
Make sure you bleed the coolant. Sounds like there was air in the system that the heater was letting move around.
~Cheers~
Old Jun 12, 2011 | 09:57 PM
KrayzieDxC's Avatar
Khmer Pride
okay now my rpms jumps up and down, is this the idle control valve??
Old Jun 12, 2011 | 10:35 PM
Go90go's Avatar
大日本帝国
Could be. Pop off the cover and make sure the yellow thing is tightened. If that doesn't do it, maybe there's a vacuum leak, so check your lines. Sometimes, you can hear it hissing.
~Cheers~
Old Jun 13, 2011 | 08:33 AM
KaMLuNg's Avatar
go90 already mentioned this, but it is very important you completely bleed the system... it usually takes me about 30 mins to do properly and with the front of the car jacked up to help the air bubbles work their way to the top of the radiator... you will get very noticable rpms jumping if the IACV isn't submerged in coolant... may have air pockets...
Old Jun 15, 2011 | 06:17 PM
KrayzieDxC's Avatar
Khmer Pride
2.5 radiator the same as 3.2tl? my radiator has a crack
Old Jun 15, 2011 | 09:22 PM
main70072's Avatar
No, they're different.
Old Jun 15, 2011 | 10:18 PM
tmnhs81's Avatar
Time to get new radiator..
radiatorbarn.com
Just priced one. Its around $85 shipped!
Old Jun 15, 2011 | 11:20 PM
KrayzieDxC's Avatar
Khmer Pride
radiatorbarn.com
got one 80.00 shipped local...suxs i cant pick it up
spudweb
May 22, 2016 02:39 PM
polish_pat
Sep 30, 2015 12:22 PM
juanrl
Sep 29, 2015 03:25 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
kingbharj
Sep 25, 2015 07:25 PM
