Odometer and Trip Meter Stopped Working
Old Dec 29, 2009 | 04:06 PM
main70072's Avatar
So just today, I have noticed that both my odometer and trip meter stopped working. I have tried to reset the trip meter to see if that made any difference, and nothing. I have tried to reset the maintenace required indicator to see if that made any difference, and still nothing. I listened closely to see if there were any noises, and could hear nothing. What could possibly be wrong. My speedometer needle that register my speed works normally, and so does everything else. Thanks in advance for your help!
Old Dec 30, 2009 | 09:50 PM
main70072's Avatar
Bump... Anyone have any ideas? I thought the odometer works with the speedometer, but my speedometer works just fine, minus the odometer. I know my speed is registered by the speed sensor, but what about the odometer? Could it be my speedometer cluster or a sensor in one of the wheels or trans?
Old Dec 31, 2009 | 08:15 AM
TexasHonda's Avatar
Speedometer, Odometer and Trip Odometer are driven by same circuit. Failure of Odometer and Trip Odometer suggests a circuit board fault on the instrument panel. A used instrument panel or repair of yours is probabaly best options. Check online for IP repair sources.
good luck
Old Dec 31, 2009 | 08:29 AM
TexasHonda's Avatar
Check car-part.com for a used IP. You may need to file a mileage change statement w/ your state if IP is replaced.
good luck
Old Dec 31, 2009 | 08:56 AM
main70072's Avatar
So it's a circuit board fault...it just seems so strange how the needle works but numbers don't roll. Thanks for the response TexasHonda!
Old Dec 31, 2009 | 03:29 PM
blueninja's Avatar
I have the same problem, is this an easy DIY or should a shop do it?
Old Dec 31, 2009 | 08:50 PM
TexasHonda's Avatar
Instrument panel removal is not hard if you follow the shop manual instructions for trim removal. I've done it once on my 2.5TL to replace the D4 light bulb. PM your email address and I'll forward the pdf files for the procedure.
good luck
Old Jan 2, 2010 | 06:53 PM
main70072's Avatar
So I removed the cluster today, shook it up and gave it some knocks. It works after putting it back together.
Old Jan 31, 2010 | 10:02 PM
perugino's Avatar
7th Gear
HELP ME Im changing my water pump and timing belt on my 1996 ACURA TL, but I can't get the bolt on the drive shaft pulley off.Is it a regular thread or revers thread. Or anyone that can help please let me know!! THANKS.....
Old Jun 6, 2010 | 08:29 PM
deej0121's Avatar
deej0121
Let's see what everyone thinks about this one. I asked my local ACURA dealer about this. The tech said he has seen the odometer & trip meter not working being caused by failed speed sensor. If I understood correctly, he thinks it is a speed sensor associated with the tranny (???). Has anyone on our forum been down this road--had a speed sensor replaced to fix this problem? Thanks in advance!!!
Old Jun 6, 2010 | 08:52 PM
Go90go's Avatar
大日本帝国
^ The Vehicle Speed Sensor goes into the differential, and is what makes your speedometer and odometers work. If that fails, then your D4 light should start flashing, and either the speedometer will be bouncy or not work at all. Perhaps he forgot that 1Gs have a differential, so he said the tranny, but it's in the diff.
~Cheers~
Old Jun 7, 2010 | 07:41 AM
main70072's Avatar
Like Go90go said, the speedometer should malfunction too if speed sensor failed. If only the odometer and trip meter stopped working, it will most likely be the cluster itself. I had this problem, but since took the cluster out and give it a nice tap/knock, put it back in and it has worked since.
Old Jun 10, 2010 | 09:28 PM
deej0121's Avatar
deej0121
I remembered the post about pulling out the cluster & giving it a shake to "fix" it, so I figured I should ask everyone here before I just go with the Acura dealer's thoughts. Thanks so much!!
Old Jun 11, 2010 | 07:36 AM
TexasHonda's Avatar
I would try Main70072's solution before replacing the speed sensor.
I don't see any way speedometer can work with a failed VSS disabling odometer/trip odometer. VSS provides signal input to circuit that drives speedometer.
good luck
Old May 15, 2011 | 02:47 AM
SimplyGheju's Avatar
I have a 1997 TL and the same exact thing happened to me today.. I have 2 questions. Was the procedure hard and do you mind sending me those PDFs for the procedure?
Old May 16, 2011 | 05:49 AM
TexasHonda's Avatar
PM your email address to me and I'll forward.
good luck
Old Aug 14, 2012 | 03:29 PM
amindian's Avatar
I have 1998 TL3.2. Its used car that I bought. Trip meter was not working when I bought it. But yesterday, my odometer also stopped. My speedometer is working fine. What would be the problem? how much would be the cost to fix this up?
Old Aug 15, 2012 | 05:29 AM
TexasHonda's Avatar
First try resetting the trip odometer to zero; several times. Sometimes this will "reboot" the odometer/trip odometer. It may be a mechanical problem w/ the gears that are jamming. If you remove suggest adding a tiny amount of machine oil to the movement and bumping/thumpoing to loosen/distribute.
Note, it could be a circuit board fault. Here you will need to inspect board closely and resolder all the connections (reheat and add a little solder).
good luck
Old Sep 2, 2013 | 09:01 AM
Redturbo0's Avatar
could you send me those pdf files? Do you have them for a 96 integra?
Old Sep 2, 2013 | 09:08 AM
Redturbo0's Avatar
wow why did this come up when I searched integra odometer not working in google.... thats why I posted, maybe its the same?
Old Nov 9, 2015 | 12:51 PM
nital428's Avatar
Acura TL 2007-- Odometer flicker, lights flashes on and off, gas gauge flickers...
Hello-- has anyone experienced this? The whole odometer flickers constantly. You can't tell what speed you're going at, the gas guage flickers as well and can't read if it's full or empty. Any information is appreciated. Dealer said we need to replace instrument cluster ($1400). Another auto shop said, it's not IC, but something to do with security connection as the clock flashes as well. Thoughts?
Old Nov 10, 2015 | 08:59 AM
TexasHonda's Avatar
Description suggests a power supply problem. It could be in harness, connector, or possibly the gauge panel. Only way is to remove panel and test power supply, wiring, etc. A multimeter is tool of choice, but a test light will also work.
good luck
Old Nov 11, 2015 | 08:39 AM
tempetom's Avatar
My problem seems to be a bit different. My D4 light quit several months back, and my trip odometer has now quit. My regular odometer works, so I'm not too worried about the 2 problems yet. I have repeatedly tried resetting the trip odo to no avail.
Old Jan 7, 2016 | 02:34 PM
larbear's Avatar
Mechanical odometer (trip setter)
My odometer (96 Integra LS) not working properly. When I reset it to 000000 it will statr there then go to 111111, then 222222, the all the way to 999999 then start all over again. The speedometer mileage is OK. Any suggestions?
Old Jul 6, 2016 | 11:48 PM
JackTheLad's Avatar
I'm keen to try this as I have the exact same issue with my 97 TL 3.5.
Can you possibly point me in the right direction as to how to do this?
Old Nov 13, 2016 | 02:35 PM
tempetom's Avatar
I posted earlier about my trip odo not working. Recently, my odometer also has stopped working.
I really don't need it, but when I take it for inspections, it may cause problems someday.
Old Nov 20, 2016 | 01:30 PM
tempetom's Avatar
OK, I bit the bullet and removed the instrument cluster. The hardest part is figuring how to unlatch the goddam connectors.
Right now, the D4 led doesn't work, but I substituted the L2 led. The trip odo and now the regular odo don't work.
I wonder if we have the stepper motors behind the PC board like the GMs that were faulty?
I can find no how tos for doing that repair so tomorrow, I'm going to a speedometer shot that claims to be able to repair instrument clusters.
I hesitate to put in a used cluster, but it may come to that.
Old Aug 20, 2019 | 05:47 PM
Joan Ferris Plachetzki's Avatar
Speedometer , odometer and a/c stopped working
[QUOTE=blueninja;11610663]I have the same problem, is this an easy DIY or should a shop do it?Speedometer, odometer and a/c quit working, now car won’t start. WHY ??
Old Oct 4, 2020 | 07:36 PM
tempetom's Avatar
I'm a little late posting that the speedometer shop was able to put another module in. The guy asked what mileage I wanted on it. I told him what it had been. Now I'm still under 100k miles. We don't go to too many places anymore.
mada51589
Jan 9, 2025 04:40 PM
SilverJ
1/2G MDX (2001-2013)
Sep 21, 2015 02:40 PM
acurajj
Sep 19, 2015 03:47 PM
vbgregg
Sep 11, 2015 05:38 PM
theinsvnity
Sep 10, 2015 10:22 PM
