new problem now
Old Dec 18, 2010 | 02:29 PM
fivestarsi's Avatar
new problem now
i have water leaking inside the dash, i drove in the rain for about 4hrs, and water is getting inside the dash. Does anyone know what i can do? or where is getting in from? maybe the windshield needs to be sealed? i have no idea.
Old Dec 18, 2010 | 04:03 PM
TexasHonda's Avatar
Put your car details in your signature line. I don't remember what you have.
Are you losing coolant? There have been incidents of leaking heater hoses inside the dash on the 3.2 TL's.
If you're sure it's rainwater, I would investigate possiblity of sunroof drains becoming blocked and spilling water into the cabin. Usually drains from overhead but might get to the dash.
I have heard of cowl drains blocking and causing leaks into the dash area, but not on Acura TL's. Easy to check. Run water in cowl and make sure it's draing away very rapidly w/o buildup (look down into cowl drain volume).
Only other possibility is corrosion pit allowing leakage into cabin, cracked windshield or leaking seal job. Has it ever been replaced?
good luck
Old Dec 18, 2010 | 09:56 PM
fivestarsi's Avatar
I have a 96 2.5 TL
Old Dec 19, 2010 | 11:13 AM
9632tl's Avatar
Radical Member
My 3.2 was leaking as well. The drains in the cowl had so much mud built up that water would just fill up in there until it leaked into the cabin. I took the wiped arms off, a.d removed the cowl, and shop-vac-ed the crap away from the drains. Took me an hour. No more leaky.
Old Dec 19, 2010 | 12:54 PM
fivestarsi's Avatar
ill have to try that. Thanks for the help!!
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
