EGR Valve
Old Nov 29, 2010 | 07:00 PM
coty's Avatar
EGR Valve
Had some problems with EGR valve before so bought a new one. Few hours later driving around and the check engine light comes back on due to insufficient air flow. What next?
Old Nov 29, 2010 | 07:29 PM
TexasHonda's Avatar
If this was same code you had before you replaced the EGR valve, the problem could be blocked EGR manifold and tubes. Whether 3.2 or 2.5 TL, both have EGR manifold/port blockage w/ time. A search will produce procedures for both I believe.
good luck
Old Nov 29, 2010 | 09:44 PM
9632tl's Avatar
Radical Member
How much did you pay for the EGR? All the new ones I find are over $300.
Old Nov 29, 2010 | 10:33 PM
Go90go's Avatar
大日本帝国
Definitely the tube. EGR valves don't go bad that often, but the tube that leads back to the manifold tends to get clogged. I posted pictures of a manifold I cleaned up, do a search for "Type II" posted by me.
~Cheers~
Old Nov 30, 2010 | 08:31 PM
Mandy's Avatar
98 3.2 Flamenco Black
Quite an elaborate DIY, simple but a lot of work. Acura charges $385 to get it done, at least that's the quote I got. 2 hours of work they said.
Old Dec 22, 2010 | 09:04 PM
coty's Avatar
Well i got one for $195 and paid $125 for it to be put on and everything is good. Thanks.
fifer16
1G RL (1996-2004)
Nov 22, 2024 07:07 PM
Mike734
Dec 10, 2021 01:25 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
prbori
Sep 27, 2015 01:37 AM
MilanoRedDashR
Sep 24, 2015 11:04 PM
