Need to replace Radiator Fan in 96 acura tl
Old Aug 19, 2009 | 12:15 AM
MsJ15x's Avatar
Question Need to replace Radiator Fan in 96 acura tl
Can I use any universal radiator fan and mount kit or does it have to be a specific part based on my model?
Old Aug 19, 2009 | 12:26 AM
TLin401's Avatar
'13 Hyundai Sonata
Stay OEM
Just buy a new radiator and install it yourself. It isn't hard at all. It takes a little over an hour to do.
Old Aug 19, 2009 | 07:24 AM
andrew070489's Avatar
^ why replace the whole radiator when he just needed a fan?
Old Aug 19, 2009 | 11:53 AM
stas2007's Avatar
Dont replace the radiator! just replace the fan; plus our tls have like 7 different sensors and plugs on the radiator it was a pain on mine cause all of them were stuck!
Old Aug 19, 2009 | 11:58 AM
TLin401's Avatar
'13 Hyundai Sonata
Well then since my idea was bad. to me.
Why not change out both fans then?
Old Aug 19, 2009 | 12:14 PM
^ because only one is bad? don't replace unless broken is my saying
Old Aug 19, 2009 | 10:05 PM
MsJ15x's Avatar
ok well to settle this, I already bought a new radiator, haven't put it in yet.
But I found out that 1 of the fans in the car don't work, and I was told it was the Radiator fan.
So I was asking because when I bought the radiator I had to call like 10 different places and give them my specs to order the radiator, so basically
can I use a universal radiator fan or do I have to buy a SPECIFIC radiator fan based on the specs??
Old Aug 19, 2009 | 11:38 PM
TLin401's Avatar
'13 Hyundai Sonata
You can use a universal fan but I doubt that it will be plug and play.
Old Aug 20, 2009 | 12:52 PM
^ buying OEM would be better i thing. i'm not sure about the 3.2, but for the 2.5 the radiator fans turn on automatically to cool down the engine. i dont know if a universal would support that feature
Old Aug 20, 2009 | 04:29 PM
DarkNinja75's Avatar
Default
3.2 does it too. Stays on for something like 8 minutes after the car is off.
Old Aug 21, 2009 | 07:08 AM
^ nice to know, does anyone know if a universal replacement will give any problems with this?
Old Aug 26, 2009 | 02:15 AM
MsJ15x's Avatar
does anyone have an idea how much the fan would cost if I bought OEM radiator fan, and is there a site that I can use to know how much all the different parts cost in the 96 acura tl 3.2 because I need to get an Ignition Control Module, and I can't find it anywhere on the internet
Old Aug 26, 2009 | 07:43 AM
the oem fan can be found - google - shopping section
you might need the ICM from the dealer not sure
Old Aug 26, 2009 | 08:42 PM
TexasHonda's Avatar
Engine-off running is not controlled by fan but rather a coolant temp switch and a fan motor controller.
Any fan motor that will fit can be wired in place w/ two crimp splices. Pull old fan, remove motor from fan shroud, and go to auto parts store (autozone is where I found mine I think). I found an Accord fan motor that matched closely enough; correct shaft dimensions (check carefully), but slightly longer. You can probably find entire fan assy on ebay for a reasonable price also.
good luck
Old Sep 1, 2009 | 10:06 PM
deej0121's Avatar
deej0121
radiator fan can be bought universal
I had to replace my 1998 3.2 TL radiator fan motor about two years ago. I found a universal fan at AutoZone. I pulled the old plastic mounting frame off the radiator and had to drill out the mounting screws to remove the old fan motor. You should be ready to do that--you will need some 1/4"-20 or 10 mm (don't remember which) screws to mount your new motor onto the bracket. I think I had to butt splice the wires onto the new fan motor, but that was not difficult. I'm not very "handy", so just about anyone can do this if I can!!!! If I remember right, Acura wanted something like $200 for the bracket/fan/motor combo. I think I paid about $30 for just the fan motor. It took me several hours to do this job, but it was not that bad.
Old Sep 20, 2009 | 07:03 PM
deej0121's Avatar
deej0121
If you look thru the forum you can find posts about replacing the radiator fan. You can replace the fan with an aftermarket fan from Autozone. I did this on a 98 3.2 about 2 years ago. You will probably have to drill out the mounting bolts of the old fan to get it out of its cowling. I looked up the fan on Autozone's website & found what looked like the right part. Worked like a champ. And a boatload cheaper than going with Acura's entire cowling/fan combo.
Old Sep 23, 2009 | 10:28 AM
Mr. Maker's Avatar
if your trying to save money get a used oem from pick and pull(local salvage yard).
Old Sep 30, 2009 | 09:13 PM
7 Tl's Avatar
hey like you guys said, the fan stays on for about 8 mins after our cars are turned off. Is it normal if the fans turn on every once in a while and not every time i shut my car off.I mean the car never over heats or any thing. It just worries me because on the 3.2's its a common thing for the fans to go on.
Old Oct 2, 2009 | 01:31 PM
96TL_X's Avatar
I just changed my left fan motor 2 months ago. I got this motor from Advance Auto for $60, its OEM. The computer showed two would fit but only the one brand Mitsuba fit. Two fans got different motors!!!
TL-Rocket
Dec 4, 2017 06:59 AM
1lowtc
1G RDX (2007-2012)
15
Nov 19, 2015 10:52 AM
iesu3423
Sep 29, 2015 08:04 AM
Bahamanurse1
Sep 10, 2015 10:05 PM
NSolace
Sep 3, 2015 08:02 PM
