More Promblems
Old Apr 7, 2009 | 11:46 AM
kcc1kjh's Avatar
More Promblems
This has been an ongoing issue with my car and I thought I had it all fixed but nope. for some reason when I try to start my vechile, it doesn't start so therefore I need to jump start it..On the first turn while i jump start, it starts up with ease. I already changed my battery, disto cap and rotor, starter. Only thing i can think of why its not startin is my alternator is going bad or I need to change my ignition swith. Wat do you guys think could be the source.
Old Apr 7, 2009 | 12:09 PM
KaMLuNg's Avatar
well if you alternator was dead, i would assume that you would lose power as you are driving... u can get it tested at an autozone...
Old Apr 7, 2009 | 12:30 PM
Go90go's Avatar
大日本帝国
If you're able to drive it for the rest of the day after jump starting, it might not be your alt. Do you have a sound system in the car? Possibly the amps aren't turning off and draining the battery overnight. It happened to me in my Accord when the remote wire slipped out and was touching 12+.
~Cheers~
Old Apr 7, 2009 | 12:38 PM
TLin401's Avatar
'13 Hyundai Sonata
Could be your battery connections.
Old Apr 7, 2009 | 01:46 PM
KaMLuNg's Avatar
yeah totally overthought that... before on my vigor, the negative battery terminal was loose... so the car wouldn't always start... have to wiggle the terminal a bit... after a while i just shimmed it up a bit...
Old Apr 7, 2009 | 02:50 PM
kcc1kjh's Avatar
yea i need to tighten them down a bit more..i got kinda lazy when i put my system in..my remote wire is in nice and tight so i know thats good to go
Old Apr 13, 2009 | 12:28 PM
kcc1kjh's Avatar
i tighten my connections and it still does it from time to time..My starter is a rebuilt so it might be crappin out on me again..this is my 3rd starter btw. But everytime i jump it..she starts right up which is strange
Old Apr 13, 2009 | 05:19 PM
Go90go's Avatar
大日本帝国
Change the terminals. That did it for me.
~Cheers~
Old Apr 13, 2009 | 05:37 PM
TLin401's Avatar
'13 Hyundai Sonata
Old Apr 13, 2009 | 07:33 PM
kcc1kjh's Avatar
another thing is that my system could be drainin my battery also. But its weird because when I turn the key, all my lights come on but I get no crank. I also hear my starter engaging so i know its not the starter. Im going to just change my terminals again to see wat happens
213swampy
15
Oct 19, 2011 10:33 AM
Klove
Aug 18, 2011 03:37 PM
kcc1kjh
1G TL (1996-1998)
Feb 13, 2009 12:16 PM
kcc1kjh
1G TL Problems & Fixes
Oct 21, 2008 10:21 AM
johntypes
Nov 16, 2004 09:40 AM
